M/T Shift Knob Questions....
my boot is not connected to **** anymore.. and can't figure out how it pops back on.. do i need to remove **** and boot from car and work on it off the caR?
i see here it says do not remove boot from ****, i guess it's a PITA to connect back https://rennlist.com/forums/997-foru...t-removal.html
also curious what ***** are available that go on using stock boot? i see the shaft just is a paddle w/o threads so i assume nobody makes just a ****?
thank you.
thank you.
If you pull the boot up from the mounting point at the bottom and pull it up over the **** (imagine pulling a T shirt you are wearing up over your head inside out while still around your neck) you should see how it is attached to the ****. There's a plastic ringy thing in there that tightens around the **** and holds it in place. You should be able to take care of it with some fiddling.
i was pulling on the back where the clips are but doesnt wanna budge, i need to pry with something but didnt want to damage the plastic. will try tomorrow.. sometimes i really wish i had the blue clip things
Take another look at the pics. The back of the boot has clips that slide under the console. Pull/pry the front clips out, then slide forward. I got the plastic tools and had no problem.
pulled and pulled and finally got it to come free, lost a clip in the process, but.... didn't need it anyways. LOL
the white part i could see the 2 teeth, and the black part has 2 gaps, but looks like someone forced it once and chipped the black part... solution=zip tie the boot up to the **** :-/
i put some electrical tape on the white piece to keep it from rattling around.
if i had removed the entire **** i'm sure i could have put the black piece up around the leather and then hot glued the white piece.. but the **** did not want to budge. i took the gear pattern plate off and saw screws but also saw the rob incased in what looked like white glue?
is this the stock SSK? or just stock stock?
![](http://i85.photobucket.com/albums/k43/rijowysock/Porsche%20Parts%20and%20Misc/photo-34.jpg)
finally got it fixed today using this DIY as what/how it should be setup, the black "washer" in mine came out which would not allow me to push it up to the **** properly
http://billswebspace.com/Porsche987ShortShiftDIY
