Oil drip
Old Apr 16, 2013 | 01:53 PM
Ante100's Avatar
Ante100
Default Oil drip
Have had my 997 from 2005 in the garage during the winter but just starting to use it now. Have run it only few times and have now discovered that it's a slight drip of oil coming.
Its a bit on the right side inside the rear right wheel.
Any idea what it is??
Old Apr 16, 2013 | 02:13 PM
Luxter's Avatar
Luxter
My initial WAG would be oil pressure sender leaking.
Passenger side, right next to rear wheel.
Easily fixable and not overly expensive, as long as my WAG is correct.
Search for sender unit leak, there are pics posted in 996 & 7 forums.
Cheers,
=L=
Old Apr 16, 2013 | 03:04 PM
Ante100's Avatar
Ante100
Old Apr 16, 2013 | 03:24 PM
Ante100's Avatar
Ante100
Here is a picture but its difficult to see where it comes from originally.
Old Apr 16, 2013 | 06:32 PM
Spiffyjiff's Avatar
Spiffyjiff
i had a leaking oil pressure sender - leaks straight down the cylinder head lid (or "valve cover" or whatever the heck you call it), and gets all over the heat shield and the front the most coil. it's an easy swap. but that area can also be a spark tube o-ring. can you maybe take a better pic? i can't quite get oriented in the one you posted...
Old Apr 18, 2013 | 04:19 AM
Ante100's Avatar
Ante100
The container for hydraulic oil is empty.
Its tiptronic so then should be the power steering but that feels normal while driving.....
Old Apr 18, 2013 | 06:03 AM
Ante100's Avatar
Ante100
Only needed to fill 1dl of Pentosin before it was up to to correct level.
Old Apr 18, 2013 | 01:37 PM
Luxter's Avatar
Luxter
One dL, uhmmmm.... Haven't heard that one in a long while
Old Apr 18, 2013 | 01:43 PM
Ante100's Avatar
Ante100
European you know
Old Apr 19, 2013 | 07:19 AM
Ante100's Avatar
Ante100
The liquid taste like cooling liquid (sweet/bitter) but the level is still high. But its a very small leak.
Any idea ?????
Old Apr 19, 2013 | 11:30 AM
Luxter's Avatar
Luxter
Any idea ?????
Welcome to the bunch!
It is not pressure sender for sure.
I actually had trouble understanding your picture as well until I looked at my car last night. Your picture shows transmission and part of CV joint at transmission from passenger side underneath behind rear wheel.
I am not sure if the line circled on your picture belongs to cooling or power steering system. My WAG it is cooling system. Will have to check it later tonight.
Have it checked by qualified tech. Don't ignore it.
Cheers,
=L=
Old Apr 19, 2013 | 12:26 PM
Ante100's Avatar
Ante100
Had the car lifted today but still couldnt locate where it came from. Just confirming that its a very small leak and that its cooling liquid.
Called 2 independent Porsche repairshops with 2 very different opinions....
-One says that I should call the salvage truck to bring the car to their repair shop.
-The other one says that its not very abnormal with slight leak after not using the car for 6 months and advised me to drive it a bit during the weekend and put a tray under the car in the garage to measure if it disapear or increase and just keep a good eye on the temp gauge and liquid level...
Old Apr 19, 2013 | 12:37 PM
Luxter's Avatar
Luxter
Even small coolant leaks lead to engine overheating.
See www.Hartech.org buyers guide # 5.
Cooling system is pressurized in normal conditions which increases coolant boiling point. With a leak in system, there is increased chance to create a local steam bubble and local overheating leading to all sorts of very unpleasant events.
Don't drive it hard. Instead drive it to a qualified shop that will properly fix the leak, evacuate air from the system and re-fill it with fresh Porsche approved coolant.
That's exactly what I would do.
Cheers,
=L=
