Mod Men: How did you modified your Carrera
#31
#36
A great thread from an extraordinay contributor:
Here are my mild mods on my .2 09' C2:
Fister hacked cans, Sharkwerks Bypass
Fabspeed tips
TechArt springs
Sports Plus software
Windows Tinted
Next up someday, I would like to get RG5 wheels..
Debating on BMC filters, and whether to add CF on some panels inside along with a "thick" CF steering wheel from MaCarbon
(I promised myself the buck stops here, as it's addictive
Fabspeed tips
TechArt springs
Windows Tinted
#37
Tastefully mod'd VG! BTW, here are some RG5's previously posted in your neck of woods. Not sure if they're still available. Also 18's if you looking for that. https://rennlist.com/forums/parts-ma...port-rg5s.html
#38
#39
Here's mine modded with a purpose. Ordered the '09C2S with PDK, Adaptive sport seats, Limited slip, PASM etc. I wanted a great road car that I could still play with at autocrosses if I choose.
I have improved the brake feel by adding the GT3 master cylinder and stainless steel brake lines. The third radiator mod provides better cooling in our Texas heat. Forged Champion wheels are stronger and much lighter than the OPEM wheels, thus unsprung weight is reduced. I have the sport chrono software without the sport chrono wart. Springs and sway bars are changed out to GT3 bars ( Tarret racing drop links) and sport PASM springs which also allow a more aggressive alignment. The Sharkwerks third muffler by pass pipes reduce rear weight by over 10 lbs and provide a better sound with no drone. Sport bucket seats are more supportive on my back than the Adaptive sport seats and significantly reduce vehicle weight. An Odessy lightweight battery reduces weight up high and forward.
Cosmetically clear corner lights and tinted windows, did I mention it is warm in Texas. The car remains a comfortable road car and corners MUCH better. With but 33,000 miles on the clock it is a keeper for a long time.
#41
I'm not sure why I bit the hook and amassed my list, it's a little scary when I add it all up. Brings immense pleasure though as my son has a 1986 944 Turbo and we do about 15 track days a year together.
2007 Carrera 4S
TechArt front splitter
TechArt side skirts
TechArt type 1 rear wing
TechArt 20" Formula wheels (19" OZ Ultraleggera for track)
RSS 7 mm rear spacers
Weissach polished exhast tips
OEM clear side markers
Zunsport grill set
Porsche third radiator
Motorad 160 degree thermostat
Mantis sump extension and windage tray
LN magnetic drain plug
IPD plenum
Fabspeed CAI hose
BMC air filter
RSS semi solid engine mounts
Numeric Racing shifter
AWE headers
AWE 200 cel cats
Gundo modded mufflers
Bilstein Damptronics
Tarret front camber plates
Tarrett front axle spacers
RSS rear toe links
RSS rear locking pins
RSS dog bones
RSS front and rear lower control arms
RSS solid thrust arm bushings
RSS front and rear adjustable sway bars
RSS rear drop links
Stoptech Trophy big brake kit (380 mm front/350 mm rear)
Pagid RS29 brake pads
Motul RB600 brake fluid
Stoptech stainless steel brake lines
Recaro Pole Position buckets
Brey Krause seat mounting hardware
Brey Krause fire extiguisher mount
Fire extinguisher
Techquipment Panamericana roll bar
Schroth GT3 six point harnesses
2007 Carrera 4S
TechArt side skirts
Zunsport grill set
IPD plenum
Fabspeed CAI hose
BMC air filter
AWE headers
AWE 200 cel cats
RSS rear toe links
RSS dog bones
RSS rear drop links
Fire extinguisher
#42
#44
My mods have concentrated mainly on my interior.
- Leather rear center console & upgraded armrest
- DCT thicker leather/carbon sport wheel
- Carbon shift **** and dash trim
- Leather inner mirror triangles & ignition key surround by Exclusive Option
Have the following on order:
- Porsche OEM Leather dash defroster vents and leather door handle spears
That should complete my leather upgrades for now.
Only other mod is a Fister Exhaust, which I truly love. Oh, and clear side markers. The sight, touch and smell of my leather upgrades, combined with the sound of the exhaust, makes the 911 that much more a delight to 4 out of my 5 senses.
Will probably do a set of wheels next.
![](http://www.6speedonline.com/forums/attachment.php?attachmentid=210148&stc=1&d=1360521944)
