Disabling PSE speed sensor.
Old Mar 28, 2013 | 10:49 AM
AWay's Avatar
AWay
Default Disabling PSE speed sensor.
Having your PSE set to 'on' and still quieting itself down between 20-40mph is a bit of a drag. I came across this information while searching for information about PSE wiring.
http://www.renntech.org/forums/topic...ools-required/
It's from the 996 forums but I have to believe it's applicable to our 997's as well, no? Seems like a very simple work around for the speed sensor.
Has anyone performed this on their 997? I have to admit I'm not sure where this relay is located.
Old Mar 28, 2013 | 11:02 AM
BAD.TAG's Avatar
BAD.TAG
Just a note from a 996'er who did this mod, its very easy and well worth the time. Just remove the diode and enjoy an un governed exhaust at all speeds. Hope its as easy on the 997
Old Mar 28, 2013 | 11:03 AM
AWay's Avatar
AWay
Did you do it on a 996 or 997?
Where abouts is this relay located?
Old Mar 28, 2013 | 11:05 AM
larrytrk's Avatar
larrytrk
Not sure we have this relay in 997's. I just have on/off switch, by passing ECU.
Old Mar 28, 2013 | 11:09 AM
mattyf's Avatar
mattyf
Originally Posted by BAD.TAG
Just a note from someone who did this mod, its very easy and well worth the time. Just remove the diode and enjoy an un governed exhaust at all speeds
Did you do this on a 997?
Old Mar 28, 2013 | 11:27 AM
jhbrennan's Avatar
jhbrennan
If you're talking about 997.1 there are lots of posts from 3 and 4 years ago on how to either disconnect an electrical plug (very easy) or a vacuum tube to have PSE on all the time. I disconnected the plug, never had any problems but there are some reports of damage to the "flaps" when PSE is on all the time. Search and you'll find this info with good pictures.
Old Mar 28, 2013 | 11:39 AM
AWay's Avatar
AWay
Oh certainly. That's how I've been running all the time, 'unplugged'. I've recently been thinking of installing a set of AWE cats however and thought it would be nice to have the option to quiet things back down when necessary. But when it's loud I want it loud throughout the rev range!
Old Mar 28, 2013 | 12:00 PM
larrytrk's Avatar
larrytrk
Spend a lot more for the remote unit or do this:
RM01 1 Channel Wireless Control On/Off : Amazon.com : Automotive RM01 1 Channel Wireless Control On/Off : Amazon.com : Automotive
The solenoid can be activated with a 9 volt battery, also.
Old Mar 28, 2013 | 04:19 PM
BAD.TAG's Avatar
BAD.TAG
No, this was on a 996. The relay it right above the fuse panel
Old Mar 31, 2013 | 10:14 PM
Any997's Avatar
Any997
3rd Gear
So I have seen the directions for disabling the speed cutoff on the 996. I guess my question is what is the most popular way to disable the speed cutoff on a 997.1 C2s? I know it is possible to disconnect the brown plug. but I still want to use my sport button for the throttle response change and to toggle pse on and off. I do not want to install any aftermarket switches in my interior. I just want to disable speed cutoff on 997.1
Old Mar 31, 2013 | 10:47 PM
Aquary's Avatar
Aquary
Yeah, count me w/ 997 owners who would like to get rid of the PSE speed-based cutout without having to have it on "loud" ALL the time.
When I searched the forum awhile back for a DIY way to do this, I didn't find anything. If I missed something, let me know!
Old Mar 31, 2013 | 11:13 PM
Any997's Avatar
Any997
3rd Gear
If the brown plug is disconnected does the sport button still activate the throttle response change?
Old Apr 1, 2013 | 10:44 AM
AWay's Avatar
AWay
Has anyone delved into the fuse area and checked if we have the same relay as the 996 that we can simply snip?
Old Apr 1, 2013 | 11:10 AM
Any997's Avatar
Any997
3rd Gear
I currently have a 2006 C2S and I looked under my driver side dash and There isn't any visible rely (with that weird German name on it) like the 996. but i think I spotted a relay cover above the fuse box. I decided to do more research before trying to pull if off......
