Blackstone analysis for early IMS failure detection on CPO?
I have a 2005 997 with 10 months of CPO warranty remaining. I'm debating on a Blackstone oil analysis to detect early signs of IMS failure before my CPO ends. If all signs point to failing IMS, will Porsche replace this prior to failure? If not, will a failing IMS cause engine damage prior to failure (i.e. should I wait until the end of the CPO to perform the upgrade or will that take an unnecessary toll on the engine?)
I would wait until end of CPO to upgrade. If the old bearing goes (unlikely) before CPO is up you get a new engine.
I also do Blackstone analysis on my oil every change just to check the general health of the engine.
Edit, I'm not so sure you can use oil analysis to convince the dealer to fix the engine while under CPO. That sounds like an uphill battle.
Never heard of a preemptive IMS putback to Porsche. Good idea.
IMS failures seem to begin with larger chucks in a not so gradual process. Might be tough to catch by the intervals of oil analysis. That said, oil analysis would be worth doing and certainly right before the CPO expires. The breakdown of the nonmetallic seal might show up.
I'd be proactive with them. If they don't do anything, I'd replace the IMS after the warranty.
Most likely they won't... I will wait another 6-8 months, if all is well, do an analysis, get a report then take it in to try. If you're unlucky (lucky), your IMS may fail by then, if not, then you're lucky? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
All is not lost if nothing happens, if all is well, and you go through CPO, just upgrade IMS after CPO and do your clutch at the same time and then sleep easy!
i would get the analysis anyway - it's only about 40 ducats incl. UPS. i get mine done after every change (more frequent since i track) and it def gives me peace of mind.
Received 5,407 Likes
One Blackstone UOA will tell you very little. It's the cumulative data points over several tests that can start to give you some (limited) insight about the engine's true health.
Porsche is NOT going to do anything pro-active based on a downward trending UOA.
Have you considered the IMS Guardian: http://www.imsretrofit.com/ims-guardian/ BTW, has anyone tried this device?
There is a place in Burlington that does them. I did one test before on my BMW to ensure all was okay do to high km's but all was good. I was concerned about Head Gasket going as I saw lots of white smoke but was not the case.
Let me know your findings.
