Mod - FVD Oil Pan plus Baffles
Old Feb 17, 2016 | 06:47 PM
  #61
floatingkiwi's Avatar
floatingkiwi
So the mantis sport 1.2l pan would seem to be the best extended pan out to get for the 3.8?
Old Feb 17, 2016 | 06:55 PM
  #62
Petza914's Avatar
Petza914
Correct.
Old Jul 23, 2016 | 03:54 PM
  #63
John997s's Avatar
John997s
Hi. I can ser that you have a 997 S (3.8L). I want to installera this Oil pan but on the FVD website they say that this product doesn't fit the S model. Have you been in contact with them about this before your purchase?
I would really appreciate a link to the exact product if you have it.
Thank you in advance!
Old Jul 23, 2016 | 04:48 PM
  #64
johnireland's Avatar
johnireland
Originally Posted by Hal
Here is what I found on the 996 M96 motor. Oil starvation occurred: 1.) On long, left hand sweepers, and 2.) When the car was running pure race slicks. NT-01’s and R-888’s of the world could not generate enough G force to cause the problem. Said another way, oil starvation would only occur when a car was on a long left hand sweeper PLUS the car was on slicks to generate enough laterial force to cause oil starvation.
So here is my question: Did the 997 M96 and/or M97 motors change the oil pickup so that oil starvation can happen under less dire circumstances than race slicks? Any feedback from the track rats over on the Racing and DE forum on this?
Would love to hear an answer to Hal's last paragraph question....
Old Feb 18, 2018 | 05:26 PM
  #65
cosm3os's Avatar
cosm3os
I need to replace the pan on my 06 C2S, and since I track the car, I'm interested in one of these pans. I prefer the FVD design because it's one piece. Why do all the websites still say its 3.6 only?
Old Feb 18, 2018 | 05:53 PM
  #66
Petza914's Avatar
Petza914
Based on Hella-Buggin making me think about tgat drain valve being plucked off by a tire gator or other road debris, I changed it to the LN Magnetic plug.
By the way, when I removed it there were some light scuffs on it from contact with something, so thanks Hella.
I also added LN's stainless steel skid plate, which is a real quality piece, unlike the toy factory aluminum offering (that also doesn't work with a deep sump).
Here's my current setup.
Old Feb 18, 2018 | 07:05 PM
  #67
cosm3os's Avatar
cosm3os
So no issues with the "3.6 only" FVD pans on 3.8s?
Old Feb 18, 2018 | 07:40 PM
  #68
Petza914's Avatar
Petza914
No idea. I have the larger MantisSport version, not the FVD one. I don't know if the FVD one has a windage tray, but that's a worthwhile addition for a deep sump. The MantisSport one is also 1 piece, plus the windage tray, whereas one of the others is like a spacer. That one created an additional potential seam to leak, which I didn't like, but don't recall if it was the FVD one or a different one. .
Old Nov 28, 2022 | 09:27 PM
  #69
jbade's Avatar
jbade
Default Any New info on the deeper oil pan w/ baffles discussion
I too have fallen victim to the oil availability issue on HPDE days. If this thread has moved would appreciate a re-direct. i'm specifically interested in whether the Mantis sump is still available? can't seem to find them on the web.
Old Nov 28, 2022 | 09:59 PM
  #70
roadie13's Avatar
roadie13
There is no simple answer to this problem. In my experience a deep sump reduces but does not eliminate oil pressure fluctuations on track. I am not sure the Mantis piece is still available; the current go-to deep sum is sold by LN Engineering (plus skid pad).
There is also this long thread about a new design for the oil pick up that might eliminate the problem altogether, but the jury is still out on that one.
https://rennlist.com/forums/996-foru...-v2-2-a-5.html
