Ate super blue or factory brake fluid
Motul if you track, OEM if you don't.
Used ate blue in my bmw. Seems like good stuff.
The blue has stained my bleeder's catch bottle and drain line some. I reckon the gold fluid should be visible enough thru the drain line. Will see for sure next time.
You should be OK with one quart.
The trick is to know when to stop (a.k.a. when the old fluid is out). That's why the trick is to alternate between blue and gold.
Here's the sequence:
Right rear first, then left rear, then right front, then left front.
At each caliper: inner nipple first, then outer nipple
