Things I wish I knew about my 997 sooner
You can adjust your review mirrors while driving on the freeway such that you no longer have a blind spot. The mirror adjustment takes a while to used to... But now I love it. Really nice side effect of having the mirrors panned out that far is that you no longer get headlamps into your eyes while driving at night. Only bummer is I miss seeing my cars hips in my rear view mirror.
Adjusting my tire pressure to the lower pressures porsche recommends for single passenger capacity (not max capacity on the door frame) has made a huge improvement in the grip of the tires.
Instead of getting in and closing the car door and then starting it... I now leave my car door open while I start the engine ... Especially cold starts. The sound is amazing!
What
What
It can be set via controls on the stalk to the lower pressure range... This is critical to do otherwise you'll get a low tire pressure warning . It's in your instruction manual... It's as easy to do as asking it to check your oil level
Thanks SB.
I am pretty sure that all Porsches have had this feature since at least 1970 as my first 914-6 had this and all 6 of the other Porsches I have had since then have them too. It's a european parking light to help other cars pass by on narrow streets when you are parked, without hitting you.
What
What
What
What
I use an "extra" seat memory button to tilt my mirrors down a tad for night driving.....
Yep. I knew about it but was reminded one day when I turned into a parking lot and then a parking space without the steering wheel centering..... thus the signal light stayed on long enough to scare me that the car might not start when I returned to the car a few hours later.
The hook on the back of the seats snags the loop at the top of suit jackets and sports coats perfectly.
Interior dome lights turn on if tilted to right ( manual on ). Centered is on when car is unlocked. Left never turns on. So depending on lighting preference when entering at night can have any combination of the three lights turn on.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
