1st Catastrophic Failure
Old Nov 2, 2012 | 12:59 PM
  #31
USMC_DS1's Avatar
USMC_DS1
Originally Posted by boolala
I have a tip. The main problem was corrosion in the cable leading from the gear shift lever to the transmission. That was the only part that was replaced AFASIK. Other than that the transmission fluid was changed and some internal parts lubricated.
That makes sense on an '05 car. Porsche had issued a TSB in '07 for the shift cables... which had higher failure rates. I had considered preemptively replacing my cables during the SSK install but my Porsche SA(former tech) indicated that my car already had the newer cables so no need... of course, that may not matter if rust was involved.
