Coolant Leak
Old Sep 24, 2012 | 02:24 PM
Luckymba's Avatar
Luckymba
Default Coolant Leak
So I noticed my coolant was down a bit. Bought some pink stuff and a new cap (just in case of evaporation) and filled it up. Went for a spirited 80 mile drive this weekend and came back and checked it. I threw a white sheet of paper down underneath what looked like the leak area. Sure enough I had a silver dollar sized pink spot on the paper after an hour - so it isn't a fast leak by any means. I guess my question is what am I looking at in the way of repair costs? Is this something that will get worse as I go or can I nurse it with more pink stuff when it hits the min? I appreciate the help.
Old Sep 24, 2012 | 08:04 PM
Matt(inMA)'s Avatar
Matt(inMA)
Not in MA anymore
Might be the water pump. They are a known weakness and tend to start to leak / fail for some around the 50K mark. Might be worth looking there. Mine water pump went from a mild squeak to complete failure in less than 500 miles.
Matt
Old Sep 24, 2012 | 08:20 PM
CORSASCHNELL's Avatar
CORSASCHNELL
Where is it leaking from based on your paper test?
Old Sep 24, 2012 | 08:36 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Unfortunately, Porsche has a history of not designing good water pumps. (Too many years in the air-cooled side?) Mine died in short order on my 3.8 engine. It typically leaks directly below the engine, a bit favoring the driver's side (left). Since the replacement under warranty I have had no repeat problem.
This is one of those areas that hits those who drive these things too little the hardest. It's what I call an infant mortality issue--that probably never got to fail for you during the warranty period if you didn't drive it enough under the normal warranty.
Miles on the car? I seem to recall mine died around 38,000 miles.
Old Sep 25, 2012 | 09:33 PM
CORSASCHNELL
One could say Porsche is rather new with water pumps, up until 1999 all air-cooled engines.
Old Sep 25, 2012 | 11:08 PM
Macster's Avatar
Macster
Why let a vital fluid leak get worse?
And coolant is a vital fluid. Just try running your car's engine for any length of time without any coolant and see how far you get.
That there is a vital fluid leak should be reason enough to have the leak fixed.
The cooling system may not be able to retain pressure under high coolant temp conditions. In this case the hottest spots in the engine can flash the hot coolant to steam which forms pockets which blocks coolant flow.
Localized overheating occurs which can in the worst case ruin the engine. Even a bad head gasket with no collateral damage to the rest of the engine ain't a cheap repair.
Or the water pump can can let go catastrophically and even if the engine is unharmed you have to fix the water pump on its schedule not yours.
Ditto the coolant tank.
Or a hose.
Or a hose fitting/connector.
Wherever the leak is coming from.
Get the leak id'd and get the leak fixed.
Remember:
A guy
Who drives
A car coolant a aleakin',
Is not athinkin'
He's gettin' by asqueakin'
My apologies to Burma Shave.
Sincerely,
Macster.
Old Sep 25, 2012 | 11:29 PM
229golfer's Avatar
229golfer
Just had the same problem. My leak was from the passenger side near the front wheel. Turns out it is just the vent pipe of the cooling system that was leaking and it is a 35 dollar part. Take it to someone who will find the source of the leak. They can do a pressure test as they tried with mine but it did not leak when under pressure...so I took it for a spirited ride and heating her up. Came back and voila. The leak was found. Good luck.
Old Sep 26, 2012 | 02:56 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
A bunch of 1977 924, 928 and 944 Porsche owners would differ with you.
Old Sep 26, 2012 | 12:00 PM
Luckymba's Avatar
Luckymba
Thanks guys. I appreciate the info - and the burma shave poetry. Honestly didn't realize how big this could get - guess I did when I think about it but that's what these boards are for, to get perspective. I have an appt at the shop on Monday.
Old Sep 26, 2012 | 09:35 PM
CORSASCHNELL
Dan
I owned a 928S and at PCA events the 911 drivers did not consider the 928 a true Porsche. Yes the Porschephiles of yore only knew a true Porsche as air-cooled and rear engine. Beating them on the rally courses did not help the matter at all.
Old Sep 28, 2012 | 12:11 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
The 928 in its day would blow the socks off any 911. It was finally a design by Porsche (Tony Lapine) that was unhindered by tradition (e.g., engine in rear, air-cooled...). The 911 mafia is alive and well in most regions.
