Will bigger battery be a problem? Operational or warranty problems
Old 09-24-2012, 09:00 AM
slicky rick
slicky rick's Avatar
Default Will bigger battery be a problem? Operational or warranty problems
H7 group size batteries fit perfectly, eg everstart maxx h7, but this size battery is not readily available where i am. Will there be any operational problems if i put in a larger higher capacity din 88 battery. The battery tray seems to be adjustable and will fit this size battery. Will there be any operational problems? Warranty problems?
Old 09-24-2012, 09:34 AM
Skibum
Skibum's Avatar
There will be no operational issues whatsoever, assuming the battery fits physically.
You should consider that with added capacity comes added weight high up in the chassis.
I can't speak for warranty issues with the car, but I highly doubt there would be any.
Old 09-24-2012, 03:54 PM
jhbrennan
jhbrennan's Avatar
See if you can get a distributor to ship you the size you want or check the non-Porsche dealers in your area and see if they have access to the size you want.
Old 09-24-2012, 04:26 PM
BoxsterG
BoxsterG's Avatar
Check Walmart or Costco. They have them in the correct size. Unless they are not near your home.
Old 09-24-2012, 04:51 PM
slicky rick
Do not have walmart nor costco where i am.
Old 09-25-2012, 05:21 PM
gpjli2
gpjli2's Avatar
Ok so higher capacity will not affect warranty or operation. It only means that battery will supply more starts and tolerate cold weather better. It will not "overdrive" the electrics or be too powerful if that is your concern. The battery box can accomodate different physical size batteries. Tech had to move clamp inside box to take my interstate.
Old 09-25-2012, 05:55 PM
alexb76
alexb76's Avatar
Get an Audi or VW battery, same OEM, with PERFECT fit, and EXACT SIZE of Porsche battery, and it's 1/2 the price (at least for me it was).
Old 09-25-2012, 06:19 PM
Skibum
Skibum's Avatar
Alex is 100% correct.
Quick Reply: Will bigger battery be a problem? Operational or warranty problems
