Please verify the Total 911 article
In the latest issue of total 911 there was an article about Autofarm and their IMS fix and engine upgrade. In it it says they have never heard of a IMS failure with the updated IMS (june 2006)? If so I would be very interested in a 2007 997 4S. Now is this right or is it that the updated is IMS get fewer failures....
My car has a Feb, 2006 build date and it has the newest version of the IMS in it, so the date in which they started putting the stronger IMS was at some point in late 2005.
The 2006-08 uses a larger-diameter bearing with a larger spindle. Porsche took the cheapest possible route: overbuild the part. There's no arguing it works. But it is still a sealed bearing in an oil environment, and as such, still subject to the same potential for accelerated wear as the earlier bearing. Enlarging the diameter of the bearing also introduces a new factor: each ball now travels farther with each rotation, meaning increased friction and wear if and when the grease becomes contaminated with abrasive particulates. The upshot is that the late bearing can probably be counted upon to last longer in moderate and low-rpm use, but less so as average rpms increase. Given that the former is probably the majority with these cars, it would account for the lack of anecdotal reports of IMS failure in '06-'08 cars and of re-failures in older cars that have had their engines replaced with later remanufactures. But in a car that is tracked, the disadvantage of the larger diameter would tend to come into play.
Thanks Palmbeacher, good input. This is what I have guessed myself. I have read most of the threads here around the IMS. However, much is related with I have a friend who had a friend and You know disaster. Knowing Autofarm is a company REALLY knowing what they are talking about this thing puzzles me. Specially thinking of what to buy, for me 997 GenII is a bit expensive using it as a daily in sweden with snow, mud and bad wheather and kids kicking their way out of the car... Best option is probably an early car with a fix installed or wait for genII to come down when the 991 takes over...
cibergypsy, where do You see the build date? Also what engine number are You on?
Thank You guys a lot!!!
997.2 engines do not have that problem, but then they got carbon build-up, which may or may not cause issues in the long-run, not enough milage/years on those cars to see for sure, but there has been many issues with direct injections on Audis and VW engines (that have been around a lot longer, and many more miles than typical 911).
AlexB76 this is My plan
what puzzles me is that it is still romours around.. Was not clearing on that.
