One week off - do I need to trickle charge?
Old 08-22-2012, 09:50 AM
  #31
Rocco07
Rocco07's Avatar
My 2003 original M3 battery was replaced in 2011. It lasted 8 years.
I feel, in part, the extended life was due to using a Battery Tender when not driven at least weekly.
Old 08-22-2012, 10:33 AM
  #32
rodsky
rodsky's Avatar
Originally Posted by Domer911
..and so I guess you thought nobody was messing with your car while you were gone?
maybe yours is gen.1. My .2 functions that way like clockwork.
Mines a 997.2 and i was just gone for 2 weeks - did not have any issues. Fob worked and it started right up. Maybe your ECU is set that way?
Old 08-22-2012, 01:31 PM
  #33
angelo1404
Shamwow!
angelo1404's Avatar
Doesn't the alarm system drain the battery over time?
Old 08-22-2012, 01:58 PM
  #34
am722
am722's Avatar
Mine fired right up without a hiccup Monday morning after five straight weeks of sitting in the garage.
Old 10-19-2012, 04:55 PM
  #35
Minok
Minok's Avatar
Default My data point: no you don't need to trickle charge for that short duration.
I'd say: no.
I just went out of country and my 2009 was parked in my garage for 4 weeks without being fired up or driven. I got back, unlocked it manually with the key, used the remote to disable the alarm, got in, and it fired up just as it always does. I did then take it for a proper 30+ minute drive.
So if your battery drains in under a month I'd bet there are things pulling power that should not be, or your not letting the battery charge by driving (eg you have lots of short trips), or the battery is just too old (but mine is 4 years old and just fine)
Quick Reply: One week off - do I need to trickle charge?
