water intrusion
i have a 05 997s cab that is cpo. the issue is in florida we get occasional meaning daily heavy rains in the summer. about 2 months ago we got heavy rain and water got in and soaked the floor under the driver side seat making the control unit located there go nuts. i took the car in and they replaced the control unit and said they cleaned out the drains which had pollen etc clogging. well a the next heavy rain the car starts going crazy again and the driver side floorboard is damp. i also noticed the door seal on the driver side is wet at the bottom where it says carrera. if they just cleaned the drains and it seems to be somewhere near the door does anyone have an idea where this might be getting in? ive checked the top seal and it looks good. the car has to be outside as my office parking is outdoors. anyone else have this issue?
Yes. I had a similar issue. There was a hole in the drainage tube that runs down the a pillar. The tube is connected to the drain in the sunroof and runs the water down Do you notice some drips of water on the cover of the speaker? The water for me would drip out of tube, and go down a pillar then drip on side of dashboard onto floor usually hitting speaker a bit.
It could be a diff problem...mine was unique... But hope to help because it was annoying
Well, i don't know. But some years ago, my son's Nissan Pathfinder had this exasperating dampness on the driver's side. About the time he was ready to sell it, we found a part of a winged seed in the drain at the sunroof. We put a air compressor to it, and blew it out, and no more wet problems.
hope you can figure it out, a damp carpet causes a moldy smell.
all the best....
all the best....
Between the door and the interior door panel is a metal panel. That panel has a gasket around the perimeter that is supposed to keep water out of the inside of the car. Occasionally. that gasket can become damaged and allow water intrusion.
Just something else to think about.
Check the rear cab drains. You need to remove the inner fender liners ahead of each rear wheel and unclog. Drains are almost at bottom. Wheels need to be removed for the project. You may also want to remove the rear speaker covers and check the drain tube that runs behind the speakers to see if it is blocked.
I (2007 997.1) had soaking wet door carpets during rain and dealer changed the metal inner door panel to resolve issue.
Although the door carpet no longer gets wet, by popping off the rubber stoppers under the doors I noticed water is still getting into the door. I figure this is not normal due to rust, etc?
MY local Porsche tech advised me as well (as rideau suggests) to watch the rear drains. They are very near the rear side windows. Drain clearing is absolutely critical on these cars. I'm extremely careful about NOT parking anywhere where I can gather leaves, etc, so I feel I'm fairly safe, but we all need to stay on top of t his.
Plastic intake manifold... at 1st I thought it looked beautiful then I found out it was plastic with aluminum paint on the outside. P-Marketing says it saves weight... seems like one of those items that was great for their profit margin as well. I'd rather see a true aluminum or metal alloy intake manifold back there... especially for future FI work.
Porsche warns against any high pressure (washing) application of water to cabriolets. They are simply not designed for that environment. However, they hold up incredibly well against normal wind-driven rain,
I had my car parked outside in heavy rain 2 weeks ago and water got into the drivers side seat and damaged pretty much all of the electrical wiring & modules. I got an estimate of $17k to replace several modules and the main wiring harness got corroded. Harness alone costs $7k to replace...... Everyone, please make sure to clean out the drain plugs annually.
2010 C2S cab
2010 C2S cab
