Gundo Hack
I took my mufflers to local Mieneke shop and the shop manager said they can't do bypass muffler with stainless steel (they don't carry it, too expensive). He suggested to use regular metal/steel but he also cautioned it can corrode quicker compared to stainless.
What is consensus of owners who had the hack? Stainless v. Metal?
2 inch pipe.
Should I paint it with VHT?
I used donor mufflers. I presume it is straight forward removal and install (for 997.1) 3 bolts from the bracket and the 2 bolts from the cat - muffler connection?
https://rennlist.com/forums/5023678-post7.html
2" should be nice and loud. The VHT might work. You can get the ceramic stuff...just make sure the surface is good and clean. It'll probably flake off over time. The DIY looks acurate.
If you can remove the mufflers and take them to the shop yourself, any muffler shop can do this mod. Plus, you will save yourself a ton of money.
If you have the shop remove and reinstall the mufflers, then it's much more critical to find a place with a good reputation.
Is there a local PCA chapter there? I'd call someone in the club for a recommendation.
Thanks for the reply! Yes, there is a local PCA (Riverside) nearby. That is where I'll be assigned when I sign up. I got the car 2 days ago. I'd like have to have the shop remove and reinstall as I don't have the space to do the work myself. I'll look into the PCA. Thank you!
