Help installing an OEM 997 Short Shift (SSK) please
Hi there
Got a Porsche short shifter for my car, got all the console out and am at the phase of removing the old shifter.
But don't want to proceed any further as am a little unsure of what to do with the cables or what the best method is so I don't mess up my cars ability to get into gear.
Here is a photo of where I am at now:-
Is there an easy way from removing the cables so it prevents need for adjustment when installing into the new shifter? Or any tips in general please?
Newbies Hospitality Director
You should have received a light green shifter alignment (centering) tool with the Porsche SSK. That will hold the shifter in the proper location and then all you do is reconnect the cable ends back into the "threads." You can see the "threads" in your picture at the lower part of the blue connector cable.
If you didn't get that alignment tool, check out this link. The PDF is near the bottom of the page.
B&M Shifter Install PDF
Go to steps 16 and 17. After you release the spring retainer clips but BEFORE you remove the cable ends mark the location of the "threads on the cable end and the "threads" on the cable receptacle. Than way you can get the cable ends back in the same position as they are now.
Hope this helps.
Hope this helps.
No, it is not a nightmare. It is VERY easy to do. The B&M instructions are very detailed, so it looks like it is more difficult than it really is. Getting much shorter shift "throws" (front to back) is well worth the small amount to time invested. On a scale of 1 to 10, with 10 being very difficult, this is a 3.
I did this swap on my '04 C2 and now on my '10 C2S. Total time is about 1.5 hours, and most of that time is spent removing/replacing the rear center console. If you get the Porsche SSk, then the shifter is already mounted in the black base (Porsche calls it the "tower"). It takes about 15 to 20 minutes to do the actual shifter swap.
Tom, plus others who have put in the ssk. What is the effect on getting to 6th? That is the only one thati really notice as being waaay out there. May of course be partly due to my muscle memory still not being fully attuned to using my right hand to shift rather than my left.... ...
Hi there
Did it all couple of days ago, much easier than expected, hardest bit is getting the console off, very fiddly.
Think if I was gonna do it again, it would only take 30-45mins.
I also went with the 997.2 GT3 shifter as its gotta metal bushings, feels no shorter in throw but a lot moe precise and mechanical compared to the stock unit, very happy with it.
I have no trouble getting it into any gear, cold or warm. It just seems easier to me. I have the OEM unit installed by an excellent Porsche tech so I'm sure that can make a difference too.
Good Luck!
Tom
You may want to get the alignment tool to get it back to center once u remove the shift cables n install the new shifter. We just did the B&M SSK today... similar install but not 100% like the Porsche SSK.
