2009 997.2S - Any recent service campaigns?
I don't post much but try to keep up with the threads and tried a search but didn't seem to find anything - apologies in advance if I missed prior threads....
Have any 997.2S service campaigns arisen in the past year?
I'll be going in for my 3d annual service in a few weeks. Almost 20K trouble-free miles. My fuel pump was replaced as part of the recall last year, and my oil level continues to read properly - no unusual oil consumption. The original OEM Pirellis in front and the 2d rear set are almost worn, so while I'm in the shop I'll have installed the Michelin Pilot Super Sports I ordered from Tire Rack before the latest Michelin rebate ended. I'm wondering if there are any campaigns I should be asking my service advisor about?
Thanks in advance.
Thanks in advance.
None that I know of. My car was in 3 weeks ago for a service. I've got 17,000 miles. It wasnt a major. But while it was in, I had it CPO'ed (purchased it off lease). Car passed with flying colors.
There was the high pressure fuel pump (HPFP) issue. Not sure if this was in the last year or prior to that.
Had it done on my '09 C2S, didn't notice any difference.
Thanks in advance.
Thanks in advance.
I was told the guidance is to replace it as soon as the owner complains of even occasional refusals to engage the starter. If you want to wait and see, just don't mention it. If you'd rather get it out of the way, tell the service writer "the car just won't turn over sometimes." That will do it.
I think you'll love the MPSS tires. My set has been great so far, both on track and off.
Gary
One simple mod that will put a smile on your face every time you get behind the wheel. Trade it for a GT3.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Thanks all for the inputs. Gary is your remark about micro switches directed at manual trannys? I should have mentioned I have PDK - I thought I've read you also have PDK. My guess is you're referring to computer switches for the clutch, which would leads me to infer PDK since the manual clutch would have a manual switch. FWIW I haven't had any starting issues, but as the car will be going off warranty in less than a year, I'll request the work if relevant. Adias also suggested I inquire about PDK re-calibration now that the car is broken in, which I intend to do.
I'll follow a straight line from my service advisor's desk to the loaner car person - don't want to tempt myself with any "mods" in the sales dept!
Thanks again.
Thanks again.
Gary
Yes, it's a six-speed issue. Actually, nothing to do with the transmission at all, but one of those hinky safety features of the last dozen years or so. The design intent is to make it impossible to start the engine with the clutch engaged. PDK units have something similar, but the switch I'm talking about is the implementation for three-pedal cars.
Gary
Gary
Appreciate the note on this. I've had some random 'will not turn over' issues, very seldomly I thought it may have been me (as in turn to start car and nothing happens). Just released clutch and repressed and it will turn over. Will have it looked at as I'm due for 3 yr soon.
Gary
Thanks for the heads-up on this. Mine is doing the same thing. I turn the key (with the clutch depressed) and nothing happens. Try again, and it works. Not comforting.
There is not a campaign per se but a number of people (myself included) have had the PDK report out various forms of failure messages and invoke "emergency run" or similar status. In my case there was no physical transmission problem (all gears were fine). But I did stop the car, turn it off, let it sit a couple minutes and re-start. All messages cleared up and none remained in the OBC message bank. I took the car to the dealer and had them double check, and they confirmed no lingering problems. If you have had any of this type of symptom you may want to let your tech know so they can test as well.
