One of the best/cheapest mods I've done
Old 06-08-2012, 08:30 PM
vern1
vern1's Avatar
I have a c4S with 5 on the front and 22 on the back. Looks awesome
Old 06-10-2012, 10:59 PM
X51
X51's Avatar
Sandwedge,
What, if anything, do the H&R lowering springs due to PASM on the car? Any special tweaks or settings required to keep everything compliant with respect to the technology settings on the car?
Old 06-11-2012, 01:13 AM
sandwedge
sandwedge's Avatar
Received 1,036 Likes on 734 Posts
Originally Posted by X51
Sandwedge,
Nothing to my knowledge. Works just like stock. Had the same exact setup on my -06 with no issues putting 45,000 miles on it.
Old 06-11-2012, 04:29 AM
Musclehedz101
Musclehedz101's Avatar
Originally Posted by sandwedge
This is what you get with spacers and H&R's.
What size Front & Rear spacers do you have installed?
Musclehedz101
Would you mind posting pics as to compare setup?
Old 06-11-2012, 10:05 PM
sandwedge
sandwedge's Avatar
5mm up front, 7mm rear. Brings both the front and rear flush with the fenders or even a hair outside. Note that this is with Champion wheels. No way I could put 15mm spacers on the rears like people do on stock wheels. Stock must be different offset than Champion.
Old 06-13-2012, 09:36 PM
malexgcab
malexgcab's Avatar
7 and 15 mm spacers will also work for 2008 997.1 NB?
Old 06-14-2012, 11:43 AM
997C2S9ff
997C2S9ff's Avatar
Yes it will also work on NB cars.
Old 06-14-2012, 12:48 PM
pewter82
pewter82's Avatar
7 and 15mm are really a perfect fit for the OEM 11" Classic wheel. Lowering the car just brings it all together..I hope to accomplish that soon.
Old 06-14-2012, 03:53 PM
malexgcab
malexgcab's Avatar
Sorry to ask this ignorant question...how difficult is it to install the spacers? Thanks for entertaining the question.
Old 06-15-2012, 06:59 AM
gota911
Newbies Hospitality Director
gota911's Avatar
Remove the wheel, install the spacer, replace the wheel.
You MUST get longer lug bolts to account for the thickness of the spacers. 5mm spacers require bolts that are 5mm longer than stock bolts and 15mm spacers require 15mm longer bolts.
Old 06-15-2012, 07:31 AM
dianic
dianic's Avatar
Avoid lugs longer than 5mm from stock. All other spacers should be the reverse bolts-washer jobbies (spacer to the hub and wheel to the spacer with stock length lugs or with washers)
The forces at play back there are huge to be messing with longer bolts in my view.
Quick Reply: One of the best/cheapest mods I've done
