Is the 997.2 an open air Engine to the elements ??
Here are some pics I just took of my Aerokit Cup. I tried to show top and bottom views of the deck lid. You will see that from the underside, with the "accordion" port removed, you do not look straight up through the deck lid vent. Air flow is drawn across through a passage in the wing and down into the filters. Any water drains out through holes in the bottom corners of the deck lid near the rubber bumpers (upper left in picture.)
I hope this makes sense. Did we really think Porsche engineers would neglect to manage this?
Apologies...for some reason the system won't let me upload the pics. I'll try again later. For now you'll just have to trust me...
update: still can't post pics, no idea why. sorry
You will see that from the underside, with the "accordion" port removed, you do not look straight up through the deck lid vent. Air flow (and any rain) is drawn across through a passage in the wing and down into the filters. Any water drains out through holes in the bottom corners of the deck lid near the rubber bumpers (upper left in picture.)
To Op, if you really want to keep the ductail look, I'd suggest find the OEM one somewhere, I was seriously thinking about it, it looks GREAT IMO, but as long as it actually works and does its purpose of both channeling air into the engine, while channeling water away!
Here are some pics I just took of my Aerokit Cup. I tried to show top and bottom views of the deck lid. You will see that from the underside, with the "accordion" port removed, you do not look straight up through the deck lid vent. Air flow (and any rain) is drawn across through a passage in the wing and down into the filters. Any water drains out through holes in the bottom corners of the deck lid near the rubber bumpers (upper left in picture.)
The rear deck is hollow fiberglass that acts as an air plenum. Each accordian continues upward into a hard plastic snorkel that opens into the upper (front) part of the deck interior, in front of the intake grilles. Intake air and water pass over the outside of the snorkel. Water (large droplets, at least) cannot make the tortuous turn toward the front and will drain through the deck to the openings at the lower (rear) corners. Air makes the turn into the snorkels (two intakes with the Powerkit).
Now I can start dumping wash water into the air intake grilles without fear of drenching the filters (or worse). And watch to make certain that water exits through the drain openings!
mzn50, this probably doesn't address your question. If you have a solid deck lid, or "hard duct" directly to the filter box, you will need a different method to separate water from combustion air.
You wouldn't want water to cause any electrical issues, i.e. coil packs, arcing plug issues....etc...
Cleaning an engine today can be tricky with all the possible electrical gremlins you can unwittingly cause by getting water on things.............
I'd be very worried to have water literally POURING onto my air filters. The stock filters are dry paper filters. They need to STAY dry. They will become water logged and get spongy, then they could possibly fail and rip open. It doesn't take to much imagination to see a possibility of water ingestion by the engine. Wouldn't take much water to cause hydro lock, totally destroying an otherwise healthy motor. Your warranty will be null and void at this point, since aftermarket parts caused the problem.
Didn't the installer have any second thoughts about installing this?
Good luck sorting this out.
Thanks Bob.. these are the pics that Bob(Hammer) had sent me earlier..
from what I see.. I have the same rear deck and is hollow fiberglass that acts as an air plenum.. drainage is done via 1/4 inch holes near the bottom of each the stubbies.
What I dont have is that cover over the accordion which is inbetween the accordion and the grill..which would stop the water from going directly into the air intake.. I presume the odd drop would be ok as there are exhausts holes..
I presume I can get a 2 "plates" made(as in the 3rd Pic..) as Im missing those.. and find a way to put them in between the accordions and the grill .. leaving space for ample air to get in.. while having the water pour in to the hollow fibreglass and exhaust at both holes that are found at the bottom..
another Question .. is the area where the FAN is also covered ??.. or is that open to the top grills ?
thanks guys.. looks like a little project
Matt
Matt
It's my understanding that Porsche will only sell the "Sport Classic" specific parts to Sport Classic owners. They don't want a bunch of copycats running around.
Matt, I just arrived at work so cannot look at the car. But I am 99% certain that the fan exhausts into the deck and out the grilles. It's the only source of water dripping onto the engine when I open the lid to tidy up the engine bay after car washing.
Anyone know whether the fan only runs with the engine stopped? The only time I have witnessed it running was after driving home from purchasing the car in early July. It was mid-afternoon and very hot ambient.
JH .. that is interesting.. I always thought the reverse//
So.. Porsche just got back to me at a "Field" Level this time..witht he following response :
"Hi Matt, just spoke with my Porsche Master Tech. No concern whatsoever! He was very quick to respond on this! Even from the factory, the rear decklid is open to the elements so you are 100% ok."
All to say that I will prob Still build the Baffles.. as a comfort thing
PM sent..
What I did is mimic'ed Bobs pics above.. I painted my grills and the 2 plates..with a heat resisitent black pain.. used polyurethane adhesive (Black) and used that to first glue the plates to the grills.. and then once dried.. grills to the Fibreglass tail..
rock solid..
Pis Pic shows water drops.. as I tested the water flow..
But again.. Porsche Master Technician told me this is not necessary..but I did it anyway for more peice of mind
rock solid..
PM sent..
rock solid..
rock solid..
