Is the 997.2 an open air Engine to the elements ??
Ive noticed that with my ducktail and other air intake deck lids on 997s that water can easily enter the engine chamber of the 997.
I was told that the 997 Engine are made to support being rained on..these intakes below are right above the Air filters ..
Can anyone confirm or have looked into this ?
Should I be concerned ?
thanks !!
thanks !!
When I wash my car the engine does not get wet at all. Only when the louvred cover is lifted does water drip onto the engine.
Never seen a set up like yours before Matt. I would of thought that there would be some water deflection there somewhere ? has to be ?
If your air filters become saturated with water they won't work as well. Who makes that tail you have? I would have expected some sort of deflector there to divert water away from dropping directly onto the air filters. Either that, or don't get it wet!
Getty Design.. says that
"911 engines are open to the elements both air and water get onto the engine. The air filter makes sure only clean air enters the intake. "
I guss Ill find out on first rain fall..
When you get an opportunity to look at a 991 with the newest duck tail from the factory, take a look to see how they deal with water intrusion. I think the Getty Design comment is weak, and shows that they are more into cosmetic designs than a design that reflects any sound engineering. You do not want water coming in--potentially in the quantity that such a design will allow. A simple baffle is what should have been included within the design--but only visible inside the engine area.
Aerokit Cup rear deck design does the same thing as OP's ducktail. Mine is not a daily driver, so I keep it out of the rain and try not to hit the area for long with a water hose while washing.
Porsche has had the Aerokit for many years, so I am certain that proper precautions (drains) are present in the air filter boxes.
Now, I do not know exactly how Getty design is, from these pics they look different and I AM SURE, the OEM has thought about channeling water AWAY from Air filter, same as the Aerokit. I do not think *Getty* would have the same resources to do extensive design and testing of their spoilers.
That's why you have the ducts that goes from the deck and connect the airbox to the air opening. they have a curvature with holes that drains the water. Also, the airbox has some drain point at the bottom....
Alex.. isn't the sport classic like a $200K model ?.. Im taking a OEM ver of our 997 models ..
in anycase.. everything I read is that Getty design is top notch and have to admit.. the fit an finish is excellent.. plus i love the look it goves my car
now.. my question is about the ducktail I installed and customized already.. not going down the hole of OEM against non-OEM .. Ive committed and love the Getty look and cost option it brought.. im just concerned about water intake..on my unit and just looking for insight
thanks
thanks
thanks
thanks
Anyhow, see Joels' response above, there must be ways to channel the water, "they have a curvature with holes that drains the water". If yours doesn't have it, then you risk exposing your engine to water and elements.
I am sure Getty look is nice, even fit and finish, but for an integral part of your car and something that could cause issues for your engine, I'd stick to OEM, or try to find a solution for that ductail.
