Ignition issue
997.2
I seem to have a ignition issue.. I think
I put key in.. Depress clutch... Turn key.. Nothing..
Restart process 2-3 more times and she finally ignites..
I even get a "Depress Clutch" displayed..very odd..
Anyone ever experience this ?
Thanks...
Matt
Thanks...
Matt
Newbies Hospitality Director
It is probably not an ignition issue. It is most likely the clutch switch/sensor going bad. It is a safety measure to keep the car from starting if the clutch pedal is not fully depressed. Should be a warranty item.
It can seem depressed but the part, which is plastic, I think is not disengaging the saftey mechanism stated above. I had mine replaced once already, easy fix. If you push real hard you will see your car start. It's not a full fail item as much as one that deteriorates. It's a warrenty item.
Cheers.
Cheers.
