Porsche Short Shifter Installed Today
Newbies Hospitality Director
My wife gave me a Porsche Short Shifter for my birthday. It arrived on Thursday and I installed it this afternoon. I really like the shorter throws and I also like the OEM smoothness of the shifter. As otrhers hace said, this is the way it should come from the factory.
I had installed a B&M short shifter on my '04 996 and, while I liked the shorter throws, I found it to be a little too mechanical and not quite as smooth as the OEM stock shifter.
Good to hear about the "OEM feel." I need to do this.
Back when I got my BMW E90 (1st stick shift in Atlanta BTW), they didn't really have after-market SSKs well-sorted. Bought one and my favorite indy shop had to do some fabrication to get the thing installed. The thing never felt better than "extremely notchy." Took three more years, but the linkage finally gave up the ghost and I had to limp to the shop in either 3rd or 4th gears only. Not fun sitting at a traffic light knowing I'll have to start off in 3rd.
How did the install go? time and difficulty?
What a nice wife Tim. We can both consider ourselves lucky in that department. It certainly helps with this obsession.
The install went well and I followed these instructions 997.2 Center Console Removal DIY to remove the center console, which is from a GT3. There are a few very minor differences between the GT3 console and the Carrera/Carrera S console. The 997.2 console is quite different from the 996 console, mostly at the front end.
As for the time involved, I spent about 2 to 2.5 hours, but I took my time. I did have to remove the console a second time after it was about half way installed because I lost one of the spring clips which secures the "Passenger Air Bag Off" tab to the console. I ended up using one strip of electrical tape on the side of the missing spring clip to increase the thickness of the warning light housing so it would fit snugly into the center console.
That's a lovely guesture from the wife. I had to buy my own and fitted it a couple of months ago. So pleased I did, the gear change has always been a bit tough on my car to get it into first and doesn't feel that much more difficult with the SSK. I love the shorter throw, wouldn't go back.
UPDATE: I forgot to add the measurements of the Porsche Short Shifter versus the stock shifter.
I took the measurements from the Trip Button to the center line (that goes side to side) on the shift ****. I measured the shifters in 3rd gear and 4 gear. Here are the results:
.......................................................[Stock Shifter..... Short Shifter
3rd Gear distance from Trip Button........ 4.125 inches........4.750 inches
4th Gear distance from Trip Button........ 9.000 inches........8.250 inches
Total "throw" distance from 3rd to 4th... 4.875 inches........3.500 inches
Total reduction in "throw" is 1.375 inches, which is a 28.2% reduction.
BTW, I absolutely LOVE the short shifter!
Basic Sponsor
Glad you like it Tim....as you know, we like it too, though we are the primary distributors for the million-mile warranty, B&M Short Shifter for Porsche. The reductions are a bit more on the B&M so you get to about a 3" on 1st-2nd. Enjoy, drive safe, and get your **** to Charlotte.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
I keep reading about a little more difficulty getting into 1'st gear when cold. My '08 (not SS) goes into 1'st a little bit harder when cold, but the first to SECOND gear is pretty tough. Absolutely fine when warm. Anybody have this issue??
When my car/transmission is cold, going 1st to 2nd gear is more difficult. It was that way with the stock shifter, so it is not something that started after I installed the Short Shifter.
When cold, if I shift at lower RPMs like 2,500 to 3,000, I fee resistance when going into 2nd gear. I have found if I get to about 3,500 to 4,000 in 1st gear then shift into 2nd gear, the shift is much smoother.
I have an '07 C2S w/ factory-installed (when the car was new) SS, and yes, I can confirm that a 1-2 shift and a 2-1 shift is tough* (*not smooth, not to say "difficult") for the first ~5 minutes of driving in stop-and-go traffic in cold weather (I live in Washington DC). After the car is warmed up, however, it's fine.
