PTS Nozzles - Swap out Instructions
Poseur
The other day Eric (of Bumper Plugs fame and Rennlist sponsor) suggested I put a couple of PTS Blue Turquoise Bi-Xenon highlight washer nozzles onto my car. As you may recall, it was a ridiculously expensive option from Porsche when ordering the car.
So I broke down and shipped out my meager cash to Eric and he quickly sent me the nozzles in 3AS -- Blue Turquoise, for those who are Paint Code challenged.
The de-installation and re-installation is much easier than you would expect. Of course, it takes some skill (not that much) and a couple of tools.
Eric suggested that I remove the headlights in order to get better access to the nozzle with something like a tape-protected screwdriver. I began to deviate from Eric's instructions when I just felt that the screwdriver wasn't working for me.
He mentioned that once you get a hold of the nozzle (held down by suction) you might need a second set of hands to retain the assembly in the deployed position so that you can advance to the next step--to insert a small screw driver to raise a tab so that you can pull off the chrome nozzle.
Knowing Porsche's modern assembly methods, I decided that their method of installing things would be (1) quick, and (2) simple (to include the right 'clocking' or orientation.)
Anticipating the use of ViseGrips instead of another set of hands, I elected to tape up the area around the nozzle with tape to protect the finish from the ViseGrips.
I discovered that the best tool to pull up the nozzle (against water pressure) is a cotter pin removal tool--covered with tape. I, too, removed the headlight first for better access.
With the cotter pin removal tool, I was able to get enough of a grip on the nozzle to pull it straight up and then with my other hand, set the ViseGrips. Nothing to it!
I then looked over the assembly carefully with a bright light to sort out the retention device. I happened to have a small jewelry screwdriver and use it to raise the tab and then was able to pull off the old chrome one.
Putting on the new one was very simple. Just press down until it clicks.
Reinstall the headlight and move on to the other side.
I believe that using the cotter pin removal tool may allow you to skip having to pull the headlights.
A more finished look!
And typical of Eric's fine work, the paint is a dead on match and the finish is superb! Thanks, Eric.
(How's that for a plug for "Eric's Bumper Plugs?")
cbracerx (08-04-2021)
Basic Sponsor
Holy smokes! Best. Writeup. Ever!
Thanks....looks great.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
Poseur
Saludos, Eduardo
gdonn7 (12-31-2023)
The painted nozzles may be absurdly expensive from the factory if you could care less about the stock chrome look ones. For me, I'd have paid double the $295 for the PTS nozzles on my GTS because, irrationally, the chrome nozzles bothered me so much on SY C2S. Whether or not the price is absurd is perhaps relative to the utility you get out of something - hmm, was that ECON 101?
hey dan your car looks better yet again. i also did that mode on my pcar with the only difference that i did not have to remove the whole assembly as you have. if you notice the chrome piece has a small hole on the side. using the jewelry srewdriver you can remove the chrome piece itself. its another way to do it but like we all say whatever works and as long as we get things done all is ok.
Looks GREAT!
Hey Edgy,
Just followed your technique and painted my washers. Since my 997 is standard black I simply used a can of Duplicolor that claims to match the Porsche black. I didn't remove the chrome caps; I was afraid I'd break the tabs so I simply masked off the plastic stem and nozzle area. I used a base coat of an adhesion paint first and followed up w/ a clear coat to protect the black finish. IMHO it turned out pretty good.
Thanks for the tips.
Poseur
Nice job! Glad it worked out so easily for you. Simple! And a lot less than what others have to pay for such a simple thing.
