Coolant leaking out quite aggressively?
Had a low coolant light on the weekend so filled it up with almost a gallon of coolant. Drove to work this morning and saw coolant starting to run out from a tube (i presume) right up by the passenger front fender. Thought it was just a bit of overflow but when I came back after work it was apparent that quite a bit had come out and the warning light came back on.
Went to pick up more coolant and noticed it was coming out again when I parked at the autoparts place. The warning light goes out once the engine warms up nut its losing a lot of coolant.
I have already replaced the cap so it is obviously something more serious. Suggestions? Its a 2006 C4S
Very likely the hose just came loose. They're just spring clips. It's quite easy to fix once you get all the undertray bits off. Same thing happened to me.
BTW I've read you should not put standard auto-shop coolant in these cars! The OEM fill is some weird polymer junk that supposedly congeals when mixed with normal glycol stuff.
Looks like i will have to drop at the mechanic - no time to be crawling around under there this week.
I just used regular pre mixed antifreeze that is supposed to be ok for all cars. Is the Porsche stuff really something that NEEDS to be used or just another Porsche fable designed to get you to buy their overpriced stuff?
I checked some threads but didnt find much but will look again - thanks
Funny thing is that I refilled it this morning, drove to work again and as of right now, there is no leaking. If its a loose hose then it seems to pick and chose the times it wants to come loose
if you `re lucky it is hose mount, if not - a small hole in the radiator. see here DIY of how to take off front bumper, it is not hard, then investigate. suncoast may sell new radiator if needed.
https://rennlist.com/forums/997-foru...carrera-s.html
sorry here is a direct link to front bumper removal
http://gallery.rennlist.com/gallery/album430
Coolant at dealer $40.00/gal. From Suncoast $25.00. In some other archive threads others have said that Volkswagen coolant is the same as for Pcars. Jury is out. Maybe we should ask Loren at renntech.com.
http://www.pelicanparts.com/techarti...ATER-Flush.htm
I believe the Porsche coolant is manufactured by ELF. They also provide the same coolant for VW and Audi so you may be able to find it cheaper at your local VW/Audi dealer. For me it's just easier to call Ryan at Suncoast and have it delivered to the house.
i really doubt there is any truth in 'special' coolant for 997 cars as plenty of track only porsche cars - gt3, strreet and cup run on pure water with waterwetter with no side effects. regular coolant would do nothing bad imho but if manufacturer wants us to use $40 per gal mix - why not.
Why not? Its $10/gl for Prestone. If there is a real need for the Porsche "special" coolant then I would use it. But as I said before if its just that Porsche wants you to spend $60 on coolant (and hence the reason for their recommendation), then no thanks.
From Wayne on that Pelican thread "The reality is that any good, modern coolant will work"
my last post-season re-build with clutch work, new AOS, new RMS and other bits went above $6K, honestly, $10 for coolant or $100 makes no real difference. plus,like was said, suncoast sells it for $25.
there are probably reasons on why they advice on this bramd and not other but most likely it is all driven by inter-brand wars as VW/Audi stuff is trying to sell what is theirs.
i would not overestimate importance of that stuff. use any coolant you find fit, add some waterwetter to it, watch temperature, if it stays normal then i would say - everything is tip-top. more important issue than just a brand of coolant is to make sure you do not have air bubbles in your coolant hoses - you need to be careful with disconnecting radiators or get a special vacuum tool to suck out all air out of cooling system, also always pre-fill radiators when you`ll mount them back.
Thx. Any special precautions when toppin off the resivour?
