Dectane Rear Light Install
I'm going to tackle the LED light install tonight. Is it a hex screwdriver needed to remove the lights? From reading other posts, it sounds like most people install the lights without the resistor packs and then if they have problems, they'll install the packs. Is this correct? My car is an 07 C2S.
It's the centre screw, which, IIRC, is a Phillips head. I installed the resistors and have not had any problems. From what I was told, it doesn't hurt to install them, so why not.
Okay I have them connected up. I did need the resistors. 2 last questions. I seem to remember someone talking about drains? Is there something i need to install or take a plug out? Also, how have people mounted the resistor? I assume in the taillight area with double sided tape?
