IPhone 4S/ PCM help
Its seems when i access the phone book on the pCM,all the conracts are displayed trippled. Is their a way to fix this? Thx
Get rid of that iPhone 4S!
If you already had a previous contact list in the PCM, maybe you chose to add instead of overwrite / replace?
1 Post
I have a 2010 997.2 and an iPhone 4S, and they work without problem.
All I did was to delete the previous phone pairing device in the PCM (especially, my old phone had the same number as my new iPhone 4S), and then I added/paired the new iPhone 4S to the PCM.
Regards,
Regards,
Agree with axhoaxho,
PCM will pick up all avaiable lists of contacts, so if it is on the phone and SIM card, you will have double list etc
You could delete all lists but one delete previous connection and reconnect bluetooth if you prefer
It seems with the new IOS 5 software update, all your contacts from all your contacts are dispalyed on the PCM. I.E contacts on the phone,mobil me, and i cloud. The fix, set up a new Contact list on your phone and just check that list to display via bluethooth.
