XM and Traffic Monitor Service On PCM
Hi Guys - on my new 997.2 I have XM and Traffic Monitor. How long do we get this for free? The car was sent from another dealer in PA. Do we even get XM and Traffic service for free on the 911? Wondering if the other dealer is flipping the bill and how long until they realize that they shouldnt be paying for it
I have XM on my 09 and XM Traffic.
XM radio is great, XM Traffic sucks.. main map keeps saying rerouting for traffic and no overlays occur, you have to go to info and manually search for your route to see maps with traffic info.
Anyone else can chime in, maybe my system is not working correctly.
Poseur
Sadly, the system works terribly in the states. It's perfect and seamless in Europe. (And free, there, BTW). America has less alternatives for route congestion than Europe has, in general.
I've had the XM navtraffic service that overlays traffic data on the nav maps. (MY 09 car with PCM3)
Navtraffic gets the data from the data sources.. .they don't generate it.. so if, in my case WADOT doesn't provide the feed, then navtraffic cannot provide the feed. I've had cases where navtraffic had no data feed but wadot still had thier website updating fine. Not sure who dropped the ball there.
navtraffic works ok for major issues, but it lags.. so its not like its live, as in 2 minutes ago something happened and you will be rerouted. By the time a congestion shows up on the navtraffic maps, its probably 15 mins past the event.
The big issue is the colors don't correlate to what I would call 'usefull values'.
I've seen interstates marked for 60mph having slowing 30-45mph traffic backups ongoing and the navtraffic still shows green. I suspect that navtraffic green and the next step down (yellow) and the bottom step (red) do not relate to the speed experienced relative to the posted limit, but relate to the actual speed. So I think red may come in at stop-n-go or 10-15 mph traffic and yellow for up to 30-35mph, but if traffic goes above 35mph in any consistancy, the map shows green even if the posted limit is 60 or 70. From my own view, I'd say if the experienced speed of cars is 10mph UNDER the posted limit, its yellow.. so once we get traffic traveling 50 in any significant quantity in a 60mph zone, it should be yellow, and once its 30mph below (or less than 1/2 the posted normal limit) its red.
That said, in the Puget Sound region there are so few alternative options that I've still driven onto congested (per navtrafic overlay) roads because there were no options, but I like to know, as I hit the interstates, which options over Lake Washington (one of 2 bridges or the routes around) may be massively congested.
If you have navigation guidance active, that is, it has planned a route for you for the destination you selected, and have navigation active, it will replan the route for you as traffic conditions change...(if you get the navtraffic feed). I'm 'assuming' if you have 'fastest route' (not shortest by distance) selected.
I would think that traffic does not affect the distance of a route option, but it might reroute even then.
May be better in Europe as Dan mentioned, but I really value the traffic overlay on the map as I commute home. I drive down I-270 to the beltway (I-495) in the evening, and have about 5-6 different major alternative routing options, depending of course on traffic. The map with traffic overlay helps me make a decent decision.
It's not perfect, but it's very valuable for me, and when I drive my wife's car without it, I miss it. There's also an XM traffic channel for dc/Baltimore/Atlanta that has a traffic rotation, but I rarely listen to that.
