Tell Me Something I don't know about the 997
#211
Suncoast Porsche parts sells it online. To remove the old one just use a trim tool and wedge it under the pedal and then lever it upwards as you use your right hand to hold the side and pull up. It will pop out. Then slide the new one downwards and it will pop right in.
#212
Not sure I saw this one in the thread yet:
Lock the door TWICE rapidly if you want to keep the doors locked while a passenger remains in the car. Otherwise, the alarm will go off after a brief period of time if you only lock the doors ONCE. It's in the manual.
#213
[QUOTE=kkswow12;17351935]Or just get any decent Porsche OTC program scanner tool and turn the damn thing off permanently as I did ...Beautiful xoxox
#214
Supreme trivia of the least known kind: This only applies to those who have the Sport Chrono Option.
With that option you have the ability to go into the PCM and either select "daylight running lights" or not. BUT, you only get that option when the VEHICLE IS STANDING STILL. It is disabled while in motion. (Must be a German safety thing). None of this applies if you lack the wart, because you have to go to the dealer to change that stuff for you. That function is also 'keyed' to whichever key you have in the vehicle at the time.
Only stop watch shows
Much appreciated.
Jeff
#215
If you have Sport Chrono, you have two speed limit notifications. One set on the dash and one set on the PCM. I set my PCM to 75mph to indicate to passengers, and I set the dash speed limit notification to 100mph.
#216
I haven’t done this adjustment, as I think turning on this feature makes your main headlights turn on all the time when you drive but I think Edgy is saying you make the adjustment in the PCM (eg. nav/radio unit settings), and not the indicator stalk.
Can you help me? I have the sport chrono(the wart). the only option it gives me is start timing. I have a 2008 Carrera S. Is it unavailable in this model year. Can you give me some more information as to activate the daytime running lights?
Much appreciated.
Jeff
Much appreciated.
Jeff
#217
Passenger side window is auto-up only after it's reached the half-way point on the coupe. On the cabs, the auto-up on the passenger side feature works with the window fully closed.
#218
The headlight washer system automatically sprays once for every ten times the front windshield washer system is operated
