Tell Me Something I don't know about the 997
Old 03-19-2012, 02:27 PM
  #151
Hudsondds
Hudsondds's Avatar
The cup holder locks into place if you push the center piece in after opening it.
Old 03-19-2012, 03:49 PM
  #152
Schist4Brainz
Schist4Brainz's Avatar
The button to wash your headlamps (if equipped) is hidden underneath the right-hand stalk for the windshield washers.
Tip: If you use anything other than distilled water (hard tap water, bug remover solution, etc.) in your washer fluid reservoir, don't push this button. Just head straight to the nearest car wash to wash the headlamps, cuz the headlamp washers will cover the entire car with spray and you'll want to wash the car anyway.
Old 03-19-2012, 04:19 PM
  #153
Schist4Brainz
Originally Posted by Hammer911
If you have bluetooth activated for your mobile phone, PCM will come on every time you put the key in the ignition.
Also, if BT is activated and PCM is off, it will turn itself on when you receive a call.
Old 03-19-2012, 04:45 PM
  #154
jhbrennan
jhbrennan's Avatar
And the nozzles are heated and are activated automatically every ten times you wash the front windshield.
Old 04-03-2012, 01:10 PM
  #155
ksdprasad
ksdprasad's Avatar
Originally Posted by acao
If you don't have NAV, the car's clock magically slows time down by about 2 minutes per week. I think it has something to do relativity and driving quickly.
i have the same thing, i thought of replacing my battery
Old 04-11-2012, 03:34 PM
  #156
ksdprasad
ksdprasad's Avatar
motion sensor will be active whenever you lock the car, alarm will sound when it detects a movement inside the cabin.
Old 04-11-2012, 03:44 PM
  #157
MICHAELWWW
MICHAELWWW's Avatar
You can put the top up or down at 37 mph indicated although the owners manual states 35mph, must be actual.
Old 04-17-2012, 06:11 PM
  #158
hpowders
hpowders's Avatar
Buying this car is only the beginning of your expenses. Last year I spent $3100 in maintenance/tires. This year I "got away" with only $2005. I guess that's why I named my 997 "Ol' Money Pit".
Old 04-17-2012, 06:33 PM
  #159
KeninBlaine
KeninBlaine's Avatar
My experience is opposite. I think that for the kind of car it is, the Porsche is quite maintenance free, especially compared to Italian exotics. Yes, the tires and oil changes aren't cheap, but they can be anticipated and budgeted for. And oil changes aren't as bad at Indy shops as at many dealers.
Old 04-22-2012, 08:19 PM
  #160
hpowders
hpowders's Avatar
Well, I went to my dealer for an oil change and left paying for that plus two 19" Pirelli rear tires plus a replacement for a leaking coolant cap plus freon for a total of $2005. I wasn't cheated. Just wish the tires on the 911 lasted a bit longer.
Old 09-30-2012, 01:50 AM
  #161
duke92
duke92's Avatar
If the turn signal stalk is depressed when the car is off, the front and rear corner lights (on that side only) are dimly illuminated. This is a cool feature when parking along a street at night. The dash will indicate "Parking light on"
Whipped into a parking spot and left the turn signal flashing when I turned off the car. Couldn't figure out why I had the "parking light on" message on the dash. Thought I had an electrical gremlin until I remembered the turn signal feature.
Old 09-30-2012, 01:55 AM
  #162
duke92
duke92's Avatar
Thought my light washers didn't work--don't have much use for them in Georgia. Tried pushing the little button on the wiper stalk just to see how they worked--NOTHING. Tried them again the other day with the sunroof open and the windows down (and THE HEADLIGHTS ON !!). Holy crap!
Headlight washers only work when the headlights are on (go figure)!
Old 09-30-2012, 08:23 PM
  #163
CORSASCHNELL
CORSASCHNELL's Avatar
Cup holders are designed as a secret message from enginners at Porsche. If you decode it, the message appears: DO NOT DRINK and DRIVE.
Old 01-19-2013, 05:12 PM
  #164
cam2008
cam2008's Avatar
I do like doing my own maintenance. Oil changes. Brakes,s etc. Satisfaction of saving money and a job well done.
Old 01-20-2013, 03:37 AM
  #165
Papa Fittig
Papa Fittig's Avatar
Unless a stealth one Radio Detection And Ranging detector in your 997 will help you getting a speeding ticket from the officer who pulled you over more than in almost any other marque
Quick Reply: Tell Me Something I don't know about the 997
