Had PSE retro-fitted, what do I unplug for ON ALL TIME?
Old 05-06-2011, 04:42 PM
Gibbo
Gibbo's Avatar
Default Had PSE retro-fitted, what do I unplug for ON ALL TIME?
Hi there
PSE is fitted and it sounds awsome, love the popping on de-acceleration.
Regarding to the plug modification, well mine looks different with it been retro-fitted, so here is some pictures:-
Is it the connector I have put a red circle around which I unplug?
Old 05-06-2011, 05:46 PM
Dharn55
Dharn55's Avatar
I have a 996 with PSE which is on/loud unless you switch it to the quiet mode. If the 997 is the same disconnecting that plug from the switch will make it on/loud all the time. If you want the switch to work, but don't want it to go quiet at the set speeds for "auto quiet" then there is a connection to the speedo that has to be undone. Again, this is for a 997 but I think they are bascially the same.
Old 05-06-2011, 06:44 PM
alexb76
alexb76's Avatar
How much did u pay for PSE?
Old 05-07-2011, 03:19 AM
purrybonker
purrybonker's Avatar
Yes, the circled plug is the correct one.
Old 05-07-2011, 09:25 PM
yossarian
yossarian's Avatar
This may be a stupid question, but what are the auto quiet speeds? Personally I would love to just have it on all the time with the option to make it quiet if I need.. but I would settle for always on.
Do you know if there is any resulting potential for damage to the pipes or engine. I am not sure I fully understand the mechanics hear but my reference point would be a motorcycle where you either shorten or pull out the baffles. In that case you alter the back pressure and it can be harmful... of course purples up any chrome.
Any help would be awesome. Don't want to mess up my baby.
Thanks.
Old 05-07-2011, 10:50 PM
annliat
7th Gear
annliat's Avatar
Thanks.
Done the same to my 997.2. So far no issues. Just disconnect the plug you identified. It will be on loud all the time. Think it controls a valve at the mufflers which bypasses a portion making it louder.
Old 05-08-2011, 03:32 AM
brendo
brendo's Avatar
IIRC you should plug the line also so that you don't end up with a vacuum leak
Old 05-08-2011, 08:32 AM
annliat
7th Gear
annliat's Avatar
Just to clarify, I was referring to disconnecting the electrical connector (need to depress the wire clip), not the actual vacuum hose. If you want to pull the vacuum hose, then yes you'll need to plug it up. Easier just to disconnect the electrical connector. Just my 2 cents.
Old 05-08-2011, 08:34 AM
Gibbo
Gibbo's Avatar
Why is the plug a vacuum seal too?
Old 05-08-2011, 08:52 AM
rcg412
rcg412's Avatar
just disconnect the electrical connector. leave vacuum lines alone
Old 05-08-2011, 10:00 AM
gota911
Newbies Hospitality Director
gota911's Avatar
Thanks.
I don't recall the exact numbers, but between 25 to 40 mph (approximately), PSE in loud mode temporarily reverts to quiet mode. This is to comply with some Euro noise regulations.
Old 05-08-2011, 11:08 PM
MagnusB
MagnusB's Avatar
Is the orange plug for PSE? Or what is it?
https://picasaweb.google.com/lh/phot...eat=directlink
Old 05-09-2011, 02:50 AM
brendo
brendo's Avatar
it's the damn Swiss! their neutrality must apply to noise too
Old 05-09-2011, 07:06 AM
gota911
gota911's Avatar
Yes, it's for the PSE.
Old 05-09-2011, 12:17 PM
KeninBlaine
KeninBlaine's Avatar
To the OP, that install looks a little flakey to me. I'm not sure if you have a 997.1 or .2, but at least on the 997.1 the solenoid/plug controller is supposed to be mounted on an existing bolt, not zap-strapped to the intake manifold. Like the others said, if you want loud all the time, just unplug the orange electrical connector.
Quick Reply: Had PSE retro-fitted, what do I unplug for ON ALL TIME?
