C2S vs. C4S Alignment numbers
Old 04-12-2011, 06:01 PM
alexb76
alexb76's Avatar
Default C2S vs. C4S Alignment numbers
I was wondering if there's any difference between SPEC C2S or C4S alignment settings?
I got the published list for C2/C2S... would that be the same as C4S or there's another setting for those?!
Old 04-12-2011, 09:49 PM
cbzzoom
Registered User
cbzzoom's Avatar
Good question.
I've never seen different specs for the C4. I've got the 996 workshop manual and I just looked, there's a separation section for the C4 and no separate alignment specs.
They are different though. It's hard to find people who really know how to set up the C4. I copy the Turbo setups sometimes but that's not quite right either.
Old 04-12-2011, 10:31 PM
alexb76
alexb76's Avatar
Thanks, I got the following specs, I wanna do the "performance" spec for it, but it doesn't include the C4
Old 04-13-2011, 12:07 AM
cbzzoom
Registered User
cbzzoom's Avatar
The C2 ROW Performance specs are really similar to the Turbo OEM specs :
https://rennlist.com/forums/7326472-post3.html
I'm sure they would be great on the C4 and a good place to start.
IMO if you do any track or just hard street I would go for even more negative camber. It depends how aggressive you want to be and how much twitchiness you want.
Personally I have stock suspension with
-1.3 front camber
-2.0 rear camber
0 front toe
slight rear toe in (I forget exactly how much)
It's *awesome* on the C4S, so much better. I get mild understeer on steady throttle and mild oversteer with jerky throttle, so I can throttle steer by controlling how sharp I am.
Some time soon I'm going for LCA's to get even more front camber.
Quick Reply: C2S vs. C4S Alignment numbers
