Spare Tire Kit for 997
I just got this from ebay - a few posts back, you see why (Flat Tire Story).
This a full spare tire kit from a 986 Boxster or 996 911. It has the 17 inch "bicycle" style tire, inflated, rather than the collapsed spare. I got it from Ebay for $350+$50 shipping:
![](http://public.blu.livefilestore.com/y1pJuUlZJs9N987N1lbSIG_IE76MLPo0Cw0xYHy06Z21SXSnc5IlBK7rWanEQsAM2v5_ALGoBiEl8xmqmyCTESBvg/IMG_1125.jpg?psid=1)
This tire, or so I read in some old Porsche manual, should be used only on the front - for rear flats, the front tire should be moved to the rear and the spare used up front.
I thought it would be a good idea to test it out - here's the tire on the car and you can also the tire cover, foam insert, toolkit, jack, plastic gloves, and "take-off" tire bag that came with it (also a set of wiper blades - not sure if they'll work on my car yet) - it all looks new:
![](http://zwying.blu.livefilestore.com/y1pR4i3RXfJE5Dw7jQsC7Q3jdWzYNEBPJ-bcMmGN-3UAJcLMm-y-_CITC0aJkAk6HM9Uf1ORz4UvSz8vCOa0BgRTKgLyaWg6lYf/IMG_1113.jpg?psid=1)
The clearance on the front brakes is very close and I have 5mm spacers on the car. I saw some kit that was being sold that included a spacer and I think it would be required. There's about 1/4 inch clearance - a little less than I had with the original C IV wheels with no spacers:
![](http://zwying.blu.livefilestore.com/y1plLjl-B4Ct3kvBWbj-BQUou9aFXeO3cDGlmtHLXX4jy0ic4gYDzKKmz_Z9hKXbYZWOEv_Vsyq4h4TnGzZpsZIeR4jG0irtOZs/IMG_1119.jpg?psid=1)
The tire had no air in it when I got it (yes I filled and made sure it would hold air). With some air out, it can fit up against the back of the frunk and leave about two-thirds of the frunk depth for luggage:
![](http://public.blu.livefilestore.com/y1pe2HO2hYIYqAtSmhTh_z_k6ljTKcVeEw_TssoYzzxuWbhGs2qrALKG4V0d70j0cjmvY4LknPI9f7bxYcr2GlChw/IMG_1131.jpg?psid=1)
Fully filled, it sits higher than the rubber frunk gasket, so it has to lay back at an angle with storage under/in back of it and on top/in front available. Ah, the frunk was small anyway.![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
And, amusing in a "this just keeps getting better" sort of way...
...the front tire I removed to test the spare fitment turns out has a nail in it - not ever leaking a drop of air...yet. Looks like it had a head that is now worn off only leaving the nail:
![](http://public.blu.livefilestore.com/y1p497gPlQpza5yY1Y1uaw5irFjH5rlW7cgo1QkFCO_tYpJ0mCw7En1hzct47Uti9GZo4PD4qhvas_BtskVP3fdkg/IMG_1122.jpg?psid=1)
Just the kind of thing to make me even happier with my new spare...and my wheel and tire warranty, if/when they pay up. Another call to Service tomorrow - 2nd tire in 2 weeks ...
Don't worry. Now that you have a spare you'll never have a flat. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
You had bad luck. The probability of another tire mishap if you take care of your tires is very small. Unless you drive mostly around construction zones.
Well, as you can see, I have spare oil too and have needed that, so I don't know about that umbrella effect - one can hope...
Are you driving a lot around construction yards? or kids playing pranks?
Just to add a bit of info here for others...
Be careful when looking for spares from Ebay - there are many 16 collapsible tires, but not the 17's we need. The part number is 996-362-020-0x where x can be anything from 2 to 4, with no apparent difference - just a year model thing. And in fact, in the PET parts catalog, that tire is listed as "Emergency Wheel" all the way through 997 MY 2008.
I don't know which is better, the spec'd part above or the 996/986 spare I bought. I'll keep an eye out for the other one and probably get one of those as well. The 997 tire is less diameter, but wider: 6inches versus 4in - although it is also the spec'd 997 spare, so there may be other things about it that are better for our cars too - like brake clearance - maybe it doesn't need spacers.
Here is a good post, recalled, covering using that 996-362-020-02 in a C4 by Coochas:
http://www.6speedonline.com/forums/9...-tire-c4s.html
Yes, I guess I pull it, pull the nail, see if I get a leak - if it leaks, then plug it - then have my W&T Warranty replace it.
Not entirely true. I can't speak for the 997.2 but it fits in the 997.1 laying down (you must remove and relocate the bose amp if you have it- easily done).
It's very tight, which is nice, it requires a nice little shove to get it into place which tightly secures it. you can see my other junk arranged around it. I also have a piece of carpeted plywood that covers it all up. My frunk gets effectively 8" shorter by carrying a spare.
Shown below:
Boxster spare as it comes directly from trunk (already inflated).
Collapsible spare directly from trunk before required inflation.
But lets talk collapsible - can you lay yours down on the bottom as shown in the 997.1? What is the diameter of that 17inch wheel&tire when collapsed? I'm thinking the wheel alone is 18in, then at least 2 inches for the tire - 20in or 21in? Coochas says 21in and he usually has the right info.
I'd like to get one of those also if it works better. So how do you put it in your frunk? Pics would be a bonus - I showed you mine, now you...
Understood that the non collapsibe does not lay down in the 997.1 frunk
For future ref: the collapsible fits in the 997.1 frunk laying down if you take the carpeted cardboard off and move the bose amp to the side (shown in pic above).
Really? You do see the photo I took of it standing upright? I would have taken a pic of the frunk closed, but that seemed less interesting. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
But lets talk collapsible - can you lay yours down on the bottom as shown in the 997.1? What is the diameter of that 17inch wheel&tire when collapsed? I'm thinking the wheel alone is 18in, then at least 2 inches for the tire - 20in or 21in? I'd like to get one of those also if it works better.
Just went out and measured collapsible unit I have - it's exactly 21 inches (+ or - .25 inches).
Right - don't think the ".2" has the same setup. The tire pump kit is on that back wall at the bottom and protrudes out about 1.5 in, all the way across and maybe 8in high. But with that removed, seems like a solid wall all the way down (seems like I read somewhere that the GAS TANK is right behind it).
