IMS or RMS issue with 2005 997
I recently got a bumper-to-bumper type aka "exclusionary" warranty for my '05 (30K miles), for 6 (six) more years for $4600 from Paragon Motor Club (mentioned on LN's website, that's where I read about them: https://www.lnengineering.com/ims.html down the near the bottom under "Should I Get An Extended Warranty"). The prices dealers want for Fidelity are insane. Plus, if you read the fine-print, Fidelity doesn't cover parts that fail due to "wear and tear" once the car goes past 50K miles. The Paragon warranty specifically says it covers wear and tear. The only provision is that to keep the warranty in effect, the oil has to be changed every 6 months or 5000 miles whichever comes first. Not a problem for me because that's how I'd do it anyway.
That said, my clutch pedal was very stiff, so I had it and the LN retrofit done. The cost of that plus the Paragon warranty (for everything else likely to wrong with my 6 yr old car over the next 6 yrs) cost me $1000 less than a 4 yr warranty with Fidelity.
BTW the mechanic showed me my original IMS bearing and that it was in perfect condition.
Easy Care quoted about the same rate. With $100 deductible ...$4k for 2 years of total coverage. Seems like that is the going rate for Fidelity and Easy Care.
I went with Lyndon Insurance-5yr/75k for about $4k (special affiliation rate). I had my local dealer compare their extended warranty with this. They were nice enough to tell me to go with Lyndon. I would worry more about service history and the original owner than the warranty. Cheers.
As far as it being the best insurance, for the IMS bearing failure I'd agree. For the 1001+ other expensive things that will more than likely go wrong on a 6-12 yr old Porsche, the extended warranty is likely to pay for itself at the very least, and probably well more than that.
Don't know about those 1,001+ things you are talking about. At 78,000 miles on my 2005 C2, I've had the water pump replaced. That's it. The extended warranty was too expensive for me. My only worry was IMS bearing, which is now fixed.
Good for you. The first month on my extended warranty mine needed a starter cable. Sounds rinky-dink, right? Wrong. Would've been $900 if not for the warranty. Maybe that will be the only thing that will ever go wrong on it, but past experience with German cars tells me that's unlikely. I plan on keeping mine another 6 yrs until it's 12 years old, and many things fail from age vs mileage. I find it hard to imagine I won't get my money's worth out of the warranty, but if nothing more goes wrong, the warranty will have been a waste of money. There's a first time for everything. Only time will tell.
