iPOD
Old Mar 21, 2011 | 03:56 PM
91469972's Avatar
91469972
Default iPOD
Was the iPOD cable supposed to have come with my 2009 C2S? My 2008 Audi Q7 did but the Apple Nano won't work!
Old Mar 21, 2011 | 04:42 PM
pilfjd's Avatar
pilfjd
My '09 C2S came with the ipod connector and even works with the new nano's.
Mike in CA's Avatar
Mike in CA
If you ordered the Universal Audio Interface option for your 2009, then it should have come with the cable shown below.
File Type: jpg
Old Mar 21, 2011 | 05:32 PM
vexed's Avatar
vexed
Mike's pic shows the "Y" cable which is the later version, your 2009 may have come with the cable that only has one connection to the car, mine had the older cable. The Y cable charges the ipod/iphone in the car.
Old Mar 21, 2011 | 05:38 PM
TooSixy's Avatar
TooSixy
The "older" iPod cable (that has one connection) will work AND charge early-model iPods. It will also work but NOT charge late-model iPods or iPhones. If you want your late-model iPods or iPhone to work and charge, you'll need to buy the Y cable. Suncoast sells it for around $29-30. Hope this helps.
Old Mar 21, 2011 | 06:16 PM
91469972's Avatar
91469972
Thanks. I saw the Y cable on Suncoast and wanted to make sure that was the one. Yeah mine was missing when I bought it.
Old Mar 21, 2011 | 06:35 PM
Mike in CA's Avatar
Mike in CA
Vexed, are you saying that MY 2009 Carreras came with two varieties of cable? My 2009 was built in April 2009 and came with the Y cable.
Old Mar 21, 2011 | 07:35 PM
vexed's Avatar
vexed
Yes, I will check the car tonight (either March or April build) and it came with the other cable. Just bought the Y cable from Sunset in Oregon for half of what the dealer here wanted for it. It is odd, I think earlier builds had the old cable also.
Old Mar 21, 2011 | 09:42 PM
TooSixy's Avatar
TooSixy
Mine was built in November 2008 and came with the single iPod cable.
Old Mar 22, 2011 | 12:50 AM
Bijan's Avatar
Bijan
The older single cable works with older Apple products (12 volts charge) New Apple products utilise the USB power of 5Volts to charge, so if not connected to USB will not charge. The Y cable only uses the USB connection for charging purposes of newer products, still uses the multi Apple connector for the audio connection.
Old Mar 22, 2011 | 01:19 AM
jcnesq's Avatar
jcnesq
Miserable Old Bastard
My 09 TT late 08 build) came with the older single cable but the Y cable was out or released in early 09 as I ordered one from Suncoast and thought I needed it, although it turns out I didn't. A cable is supposed to come with the car if it has the UAI option.
Old Mar 22, 2011 | 02:58 AM
vexed's Avatar
vexed
Just checked the door sticker, March 2009 build UAI came with old cable.
