Help: Side PCM Console Panel Removal?
Help needed. AM in the process of swapping out my interior to gain more contrast on my interior and just got a set of PCM console side panels in black to swap out on my car and would like to do them myself. Problem is I can't figure out how to get the old PCM panels off to install the new ones. Does anyone know if this is an easy swap out I can do at home or will I need to take the car into the dealer to finish the job. Thanks Md
https://rennlist.com/forums/997-foru...de-997-2s.html
should be easy - look at MaCarbon web for center console install instruction - you have to partially remove the side panels to do that - way easier than doing the CC.
Poseur
Check out my guide to installing the bluetooth TOOKI device. It may help you to better understand how those side pieces are attached.
https://rennlist.com/forums/997-foru...ion-guide.html
