Short Shifters for 997.1 C2S
Old 12-01-2010, 11:57 AM
backerman
backerman's Avatar
Default Short Shifters for 997.1 C2S
Any suggestions? I've been thinking about this. Thanks.
Old 12-01-2010, 12:39 PM
Edgy01
Poseur
Edgy01's Avatar
I like having it on my car. Works well. Changes the whole experience to me.
Old 12-01-2010, 12:44 PM
ecostellodo
ecostellodo's Avatar
The short shifter is great. After driving a car with and one without, I was sold on the short shifter.
I felt like I was rowing a boat with the standard shifter.
Old 12-01-2010, 01:53 PM
cviles
Unique Title
cviles's Avatar
I'm a big fan of short-shifters. I have the Porsche SS kit in my 987 and my 997 and love it, despite the increased effort to get into first sometimes in cold weather. There are other kits on the market, with proponents for each of them. But if you like being engaged with your car, and feel having a manual box is part of that, absolutely get a SS kit.
Old 12-01-2010, 02:15 PM
todd.
todd.'s Avatar
Best thing you'll do, just make sure the installer knows what he's doing. I had the OEM installed on my '07 C4S CAB, huge improvement.
Old 12-01-2010, 09:41 PM
raspritz
raspritz's Avatar
I had the B&M SS installed in my '07 C4 cab. Big improvement. But a much more difficult install than the OEM version. NOT a do-it-yourself job!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (Could I be clearer?)
Old 12-01-2010, 10:15 PM
cello
cello's Avatar
I have the OEM kit and agree with the above, with one caveat: If you plan to track your car it is much easier to do a $ shift with a SSK; OEM or not, installed properly or not. The gear gates are so close that any form of lateral Gs can get you in the wrong spot esp. if distracted. So you must be very conscious of your shifting on the track. As an example, I had a friend take my car out for a Traqmate data point (vid here: http://vimeo.com/16221390). He is a very good/experienced driver but note the difficulty he has getting the gearing down when there are lateral Gs involved (ex: T8 at NJMP T'bolt, @~2:41, etc). He would have learned the car eventually. That said, he does drive an '07 GT3 which has OEM shorter gearing throws. The point is that you still need to be careful on the track - longer gearing gates/throws gives more margin for error.
Old 12-02-2010, 03:56 PM
cab&coupe
cab&coupe's Avatar
Love mine... so much so considering upgrading to a short shift kit on my 993.
Old 12-02-2010, 08:01 PM
997driver
997driver's Avatar
After much research before pulling the trigger, stick with the OEM SSK. Feels much more engaging, not too notchy, just the right amount of throw reduction.
Old 12-02-2010, 08:15 PM
winkingchef
winkingchef's Avatar
OEM SSK is the best upgrade I did. That and SmartTop.
Word of warning : it does take a bit of time to warm up if you haven't driven the car in a while.
You can drive it, just be aware the force required is higher for the first few minutes.
Old 12-03-2010, 11:15 AM
cab&coupe
cab&coupe's Avatar
Definately notchy when cold... double clutching until warm avoids potential issues.
Old 12-03-2010, 11:20 AM
CarlJ
CarlJ's Avatar
Love my factory SSK. Highly recommended. Had a B&M SSK on a supercharged mustang once, and liked it too.
Old 12-03-2010, 11:24 AM
docfink
docfink's Avatar
I wonder why it's not standard.
Old 12-03-2010, 11:27 AM
cab&coupe
cab&coupe's Avatar
SSK was a $765 option on my C2S.
Old 12-03-2010, 01:04 PM
gravedgr
gravedgr's Avatar
I keep hearing people say "get OEM" - what am I missing? The B&M shifter sold aftermarket is what Porsche uses at the factory. Or are you folks suggesting people should avoid *other* aftermarket shifters like the Schnell? If you buy the OEM kit from the dealer vs. the kit from bumperplugs, you're simply paying more for the same thing.
http://www.bmracing.com/PRODUCTS/Porsche
If Porsche entrusts B&M to make their OEM Sport Shifter, shouldn’t you?* This B&M Precision Sport Shifter is engineered to Porsche’s strict specifications, developed specifically for the mighty 911s, Boxsters, and Cayman! Shorten the throw while removing some of the inherent sloppiness in the cable operated shifter, there really is no substitute!
Quick Reply: Short Shifters for 997.1 C2S
