I changed my battery!
I just changed my battery this morning. I connected my Ctek Porsche Dual Mode Battery charger to the lighter socket before starting.
I bought a Sears Die Hard Gold R94 for 139 dollars. I disconnected the battery as the manual stated on page 296: Black disconnected first then Red Second. When you put it back on connect the Red first then the Black. While the battery was out, the front boot light stayed on which was a good thing to see. I connected up the new battery and I saw no faults on the instrument cluster. I did notice that when I opened and closed the passenger door the glass did not automatically close the 5mm gap. It however worked on the driver's side. I went out for a ride back to Sears to recycle the old battery and by the time I got there (20 min) the passenger glass worked perfectly. I guess it reset itself thankfully. I changed the battery due to a few hard starts on cold mornings. The battery is the original, 3 1/2 years old. Winter coming here in Nude Hampster so I wanted to play it safe. This forum is giving me the confidence to do DIY stuff. I would not have done this a few years ago.
Thanks to all.
Thanks to all.
Thanks to all.
Thanks to all.
Great! Good to know that the Porsche Dual maintainer does not shut-off during battery changes.
Can you connect a standard charger to the terminal in the fuse box while you make the change? My battery is coming up on 3 years old so I will probably have to deal with it in the next year.
BTW I had a slow cranking issue early on ('08 C2S) and it turned out to be a wiring harness issue. The dealer said it waas a known issue. Warrantied.
Thanks for the heads up.
Enduro963: Any issues with installing/aligning the new battery in the existing housing? Please let me know what I should expect with the installation. My 997 just turned four years old and I'm looking to replace the battery before it craps out. Thanks.
The dimensions of his replacement are an exact match so no issues with tray or hold down clamp.
Not sure exactly what the harness problem was. It acted like a dying battery when the car was hot. Got to the point where I tried to park on a hill in case I needed to jump start. Took it to my battery shop and they said battery is fine. Took it to the dealer and they said "Oh yeah, known problem". Something about a heat shield on the alternator wiring harness (or something like that).
Still want to know if I can use a charger to keep codes alive during a battery change?
What about this: http://www.autosportcatalog.com/inde...:referralID=NA
I just replaced my battery with a Die Hard Gold from Sears. It fit perfectly in the slot. I put the edge facing away from me in first then set the front of the battery down. Then slide the battery all the way to the right as you look at the front end . The metal flange that holds the battery down fit perfectly back on holding the new battery. You also have to re hook up the vent hose on the left side of the battery and plug the other vent hose hole up on the right side of the battery with a plug that comes with the new battery. I am not a DIY guy at all and I did not wreck anything as far as I know. Good luck it is pretty easy.
Worth mentioning that to minimise the chance of zapping the electronics:
Negative cable off first, on last.
Also for jump starting, frunk opening it is covered in the instruction manual.
^ test those as I suggested above, using a voltmeter and a 100 ohm 2W resistor.
