2006 c4 wont start
2006 c4 wont start
sad day for me....car wont start and dont know why...dorve it last sunday for about 15 minutes to the movies and then went back home drove for abt 15 mn agains. Today which is thursday, i tried starting it and it wont start....i didnt leave the headlights on. The car seems to have all the lights up and when i turn the key and i hear the motor abt to do something then it simply dies....after a few tries then nothing happens at all....i also noticed my right window keeps going down as i keep trying to turn the ignition, odd huh...will try to jump her tonight...
Sounds to me like a dead cell battery (internal short),.....power there one minute, and a few minutes later its gone. You will need a new battery and all should be well. All the weird symptoms you are seeing are due to low battery power,.....Porsches don't like that.
so i jumped the car and now i have a check engine light, service workshop etc.. check gas cap and all the caps everywhere else...everything looks good and it drives fine, but light wont go away, should i be worried?? what should i do now? dealer is 2 hours away from me....argh......39k miles by the way
With all those microprocessors our cars are too complex now, like jets. Consider yourself the pilot. The plane has a malfunction. The pilot calls the maintenance crew.
Unless it's a dead battery or loose gas cap 95% of the time that's all we can do: call the maint crew.
BTW, flashing CEL is very bad = don't drive. Steady on is more like drive it short distance to service ASAP.
okay, i read somewhere that if u reset the battery the check engine light will go off if nothing is really wrong...well i did that and now the light is gone !!! yay!!! but i got another error saying PSM failure!! not a big deal, read the manual and it says its perfectly normal after battery reset, so I drove it around like the manual said too and wala, no more errors!!! keeping my fingers crossed that it stays that way!!!
Poseur
If you can self-clear all those warnings after a battery switch out then you should be good to go. These 997s are particularly hard on batteries so their lives are limited. When things are starting to go, just spring for a new battery, drop it in, clear the alerts, and go on.
