do the driving lights light up when you turn on the fog light?
i just noticed that when you pull the light switch to turn on the rear fog nothing happens to the front lights. Is this normal? i was expecting the lights in front to get brighter or the led lamps to light up to add to the intensity of the headlights...nothing happened.. is this true for all or can we program it to light up when the rear fog is turned on?its a 997.2
What I heard is that PAG decided to do away with the front fogs given that the current bi-xenons are nicely collimated (non-spreading vertical beam) and, as such, conventional front fogs are no longer required.
great. now i know there is nothing wrong with the car. the next question is maybe there is a way to turn those nice daytime driving lights on when the rear fogs are switched on. that would be a nice mod.
So unless you hack something, there's no way to have the main driving LED's plus main beams and/or rear fogs on simultaneously.
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
The thing is, the only way to engage the rear fog lights is when the headlights are on. And when the headlights are on, the 6 main driving LED's go out and just a single much dimmer LED "position light" (Porsche's term) is on.
You are, of course, correct, Mike; I had forgotten that (probably because the sun always shines here in England......)
The pull turns on the rear fog light. Nothing else. That rear fog is to be used only in very dense fog like conditions with very poor visibility (under 50m is the German vehicular code rule).
