Front License Plate Holder
Old 09-01-2010, 08:58 AM
slicky rick
slicky rick's Avatar
i know picutres, pictures..i will when i get the chance and post for everyone but i will need to disassemble for everyone to appreciate the simple frame. maybe over the weekend if time permits..
Old 09-01-2010, 11:02 AM
Hella-Buggin'
Hella-Buggin''s Avatar
Originally Posted by alexb76
How much was your ticket? It's $109 here!!!
$105 but if you fix it and have a cop sign off on the repair it's like $50.
Old 09-01-2010, 12:31 PM
LlBr
LlBr's Avatar
IMO, center it so it doesn't look odd.
Regarding the mounting bracket? Use your ingenuity and resourcefulness to mount the plate and it's bracket as far away from the car as possible; like an inch or two. That way it looks separate from the lines of the car.
Old 09-01-2010, 04:53 PM
Minok
Minok's Avatar
Originally Posted by brendo
no issues YET, with lots of motorcycle cops around here in bellevue, kirkland, seattle WA.
pls don't jinx me
I'd think its not a valid option and its a mater of time before you get a citation.
The scan applied doesn't have the reflectivity or readability of the rigid and flat plate provided by the state.
What I don't get is why we cannot just have front plates that contain only the necessary info in a small number tag like you could get by just cutting the border spam off of the plate in a metal shear. Then we could use a smaller front plate bracket.
Old 09-01-2010, 07:31 PM
LlBr
LlBr's Avatar
i had an identical copy made with a hi-res scan. so far, so good, knock wood, fingers crossed, etc. i don't really like the look but i like it better than the alternatives.
Uh Oh...? Nice work, but, I'm sorry that will likely be considered totally illegal. Why? Because AFAIK they want the highly reflective surface of the original plate for their laser guns.
Old 07-03-2013, 05:04 PM
tamara.kuznetsov
2nd Gear
tamara.kuznetsov's Avatar
i do these vinyl licence plates, if you want to order one, its $89
http://licenceplate.ca/
Old 07-03-2013, 06:42 PM
alexb76
alexb76's Avatar
Those are nice, yet still illegal is the cop wants to bug you!
Old 07-03-2013, 08:05 PM
rsabeebe
rsabeebe's Avatar
i like to keep mine under my front floor mat.
Old 07-03-2013, 09:19 PM
Bullseye7
Bullseye7's Avatar
The Skene looks best to me. Let me know if you're ordering one and maybe we could order together and split the shipping to BC!
Old 07-09-2013, 03:49 AM
SPDR
SPDR's Avatar
I've got a Skene design bracket that I don't use anymore. If one of you Van guys want it PM me.
Old 07-09-2013, 09:18 AM
deverest
deverest's Avatar
I use the rennline tow hook plate mount. I keep it in the frunk in a few pieces in case I am stopped...I calmly explain that I just got it and have not had a chance to install it...but I will officer, I promise
Old 07-13-2013, 02:46 PM
Bullseye7
Bullseye7's Avatar
SPDR, I just pm'd you.
Old 07-14-2013, 12:12 AM
mrhebert
mrhebert's Avatar
I just installed the Skene Design today, and believe it is the best option. I have already gotten used to a front license plate. The 2 holes you drill are in the underside of the non functional air scoop and you couldn't see them unless you removed the bracket and looked from underneath. It is so much better looking than the offset toe hook install. It does take some planning, but the plate will just about fit in the height of the center scoop, and does not protrude.
Old 07-14-2013, 12:47 AM
alexb76
alexb76's Avatar
Can you post some pics pls?
Old 06-07-2014, 03:46 PM
Lvt19672
Lvt19672's Avatar
Just got a no front plate fix-a-ticket, has anyone just used double sided tape to tape the front plate when you go to get the ticket signed off???
Quick Reply: Front License Plate Holder
