Money Shift
#32
Kuhan, ask them for a print out off the DME, and post the result here for the 6 different over-rev ranges and the number of ignitions in each (they are also time stamped based on operating engine hours). You will not be drawing their attention to this data, they are already looking at it too.
#33
Update: I started the car with the door open and heard a ticking noise. It's coming from the right rear so I went straight to Porsche. They are going to look into it but suspect it's a "valve lifter".
I'm dreading the call telling me that warranty is not going to cover it and how much the bill will be.
I better start saving...
Even if the noise is real, it might not be due to the overrevs. I know of a new 996 that developed a noise like you describe shortly after the owner drove the car off the lot. The lifter collapsed. Stuff happens, especially to new stuff -- that's why there is a 4 year, 50K mile warranty -- and not all of it is the driver's fault.
Do not be so quick to assume responsibility just because of the overrevs. Let the dealer make the case against you. How can the dealer say the noise would not have happened?
Sincerely,
Macster.
#34
The dealer called and they are talking to Porsche NA about who is going to pick up the tab. They said that the over-revs were recorded as high as 8,400 for a sustained time. They won't actually see what's wrong until they have responsibility sorted - then I'll find out if I have to pay and how much it's likely to be.
#35
I doubt Porsche is picking up the tab on this one. Why would they? The motor was abused.
Sorry Kuhan, this really blows.
Phil
#36
I just realized that it's only money. It's not like I'm losing a limb or an eye...
Something I shouldn't worry about. Sure, it's going to be painful but only in the wallet.
#38
#39
I just got another call and Porsche won't make a decision on the warranty repair until they know what's wrong. They need to do a teardown to find the issues which is $2400 so I said to go ahead.
I'm pretty much resigned to the fact that I'm paying for it anyway so I'm not going to worry about it - I just want my car repaired.
#40
#41
I'd make sure they inspect the gearbox as well. It would suck to get it all back together again and have that go out shortly there after.
#42
The service manager thinks it's just the top end and said that would be about $2k to fix. But he said he was just shooting from the hip - who knows what they'll find.
#43
I wouldn't spend any more money than required. If the gear box goes, it's under warranty. It's very unusual for a box to go because of a measly 8400RPM over rev.
To the OP: You probably have a good case for warranty repair if you haven't hurt your chances by telling them about the incident. I'm not suggesting you lie, but I wouldn't openly have given them a reason to deny you warranty.
I've seen dealers/PCNA do great things for customers. $2400 is ALOT of money to take an engine out though. I would have only assumed $12-1500 but I'm no Porsche tech so what do I know.
G'luck anyways!
G'luck anyways!
#44
Newbies Hospitality Director
G'luck anyways!
G'luck anyways!
#45
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
