Car Not Driven 2 Years - What Need s To Be Done?
I would strongly advise against jump starting - this is now not allowed on some modern cars as it can upset the computers.
A new or at least strongly charged battery would be my choice. I hope he did not leave the handbrake on as it may now be seized on as may the ordinary brakes however a quick sharp blip on the pedal while in gear should release them.
The clutch plate can also get seized to the flywheel but again this can be released by starting it in gear - obviously reverse gear on both counts if it has to be reversed out of a garage.
These methods may seem rough but I have been there done that and there have been no long term ill effects.
Obviously check the tyre pressures as these tyres don't really look deflated when they in actual fact are. Check the fluids. I would not go sucking the old petrol out as this can disturb sediment on the tank bottom. Just throw in a few gallons of fresh stuff.
Warm it up a bit first and make sure its not raining before taking it out the garage for its first drive.
There's always a chance of a current surge that can fry alternator rectifiers. That is often not noticed immediately but eventually kills the alternator causing an electro-mechanical imbalance. It happens more often than you may think.
Maybe, but not sure how frequent such issues might be. Dealer said it's perfectly fine to jump the car, if it's done correctly.
I do this with my cars when I pull them out of winter hibernation. The thought process is to make sure nothing has seized during storage (a very unlikely event, regardless) and to "pull" a fresh film of oil on the engine, prior to cranking with all the power and torque from the starter motor and engine.
For some Porsches, you can also do this by pulling the DME relay, crank a few times, build oil pressure, replace the relay, and fire the engine.
This is what you do:
1.Check all fluid levels: oil, coolant, brake fluid
2. Inspect Belt
3. Check for any nests from mice and other rodents in the engine capartment or exhaust.
4. Inspect wheels and tire preasure.
5. Charge battery
6. Start it!
7. Keep an eye on all gauges. Also listen for any unusually noises. Turn it off if there is any thing that is not normal!
8. Let idle until all fluids get to normal temps.
9. When you drive it take it easy. Go slow. Let things warm up.
10. Fill it up with fresh gas and take it to the shop.
Once at the dealer have the oil changed, flush the brake fluid, brakes inspected, tires inspected, coolant inspected. Have them inspect the entire vehicle. You might need new tires. Alot will depend on how the car was parked for the last 2 years. was it parked indoors in a dry biulding or a damp building. The car was only parked for two years. Thats not a long time.
Once the car is returned Wash and Wax the car clean the interior and ENJOY IT!
Just ask if you have any questions
2. Inspect Belt
5. Charge battery
6. Start it!
Speaking of rodents. We had a squirrel issue where they were hoarding dog food in the car's airbox over the winter. They packed it to the brim.
Yes those pesky critters can do alot of damage. I have seen mice chew a wire harnes on an NSX once. also mice decided to build a nest in my friends buell motorcycle exhaust... lol
2. Inspect Belt
5. Charge battery
6. Start it!
2. Inspect Belt
5. Charge battery
6. Start it!
Now if this was a 40 year old vintage car that hadn't been driven for more than 10 years, I could see the concern.
Do the above, start it and go from there.
It's not that hard to do. On a flat surface, with the car in 5th gear, I can give a good pull on the rear wheel, and get the car to move and manually rotate the engine. I do this with my Boxster. Disclaimer- I work-out 5 days per week.
Owners with a sloped driveway, can use this to thier advantage, and make it really easy.
Next Spring for the Turbo, I'll just pull the DME relay.
This is the best advice in this thread. All the rest about siphoning the gas, good luck with actually doing that and I think overall, 2 years is not that long. Now I realize a lot of people drive their Porsches regularly, but I assure you there are some that don't put 200 miles on theirs in two years, which would not burn a tank of gas.
Also add stabil to the gas next time you store it and a solar or electric trickle charge for the battery. Give Chad at Porsche of Arlington a call; he's the Service Manager and will do whatever is needed to get the car taken care of and made road ready without much hastle for your soonest. Good luck!
