Random Ownership Questions
I tried the one remote this evening and nothing happened. Its enough to light up the red key button but not enough to unlock the doors or pop the trunk. I'll try the second remote and see if that changes things.
The center button doesn't do squat either so perhaps I need to close the drivers side door or have the key in the ignition before trying it?
I'll start monitoring the oil level more often...
Many thanks for the link to the 06 997 manual as that's a good read!
Yeah, in theory but you're an old timer, perhaps a little more blase about a new Porsche (and I mean that in an envious sort of way). My 911 (on the left) was my first and my salesman was going over all the details and all I wanted to do was get on the road and drive it. He was talking, opening up the all the compartments, etc. and explaining things and all I heard was, "Blah, blah, blah" and only remember seeing a yellow blur in front of me. After about 15 minutes he figured out nothing was sinking in and mercifully said, "Well, you can figure out the rest by reading the manual" - which I did. I'm sure on the next 911 I'll pay more attention and let my sales guy go through the routine.
Unique Title
As for why the OP's key doesn't seem to do anything, I'm thinking this is a programming issue his dealer can fix.
[QUOTE=Ucube;7364635]
2) The key button on the remote should lock/unlock both doors. The trunk button should open the front bonnet.
If you have the "Indiv settings" in the "Set" menu, you need to go to the "lock" menu item and enable "both doors" for unlocking with your remote.
Sounds to me like your remote batteries are weak if you're not getting proper responses. I don't need to hold my buttons down to lock or unlock the doors. Just on click and it is done.
Spend some time with your PCM manual and checking out all the menu items. It is amazing what you can find in there.
Enjoy the car.
Enjoy the car.
