X51 Header install this week, with dyno (05 C2S)
I am also interested as I would like to do the X51 headers and air box swap in the spring.
A quick question, why doesn't any one here have the exhaust components coated to reduce heat loss? I have always had my race car headers, and at least the front exhaust section Jet Hot coated before installation. Not only does it reduce under hood temps, (I can see it doing wonders in a tightly packed 977 rear end) but it prevents any type of corrosion.
Dave
Ok so I got the headers installed. Install was cake. I just jacked up one side as far as my jack would go and slid a jack stand under the cross member right where the rear LCR pivots and lowered the jack just enough so the stand touches. I also slid the tire under the side of the car right by the jack for extra safety. Leaving 99% of the weight on the jack.
There is a definite difference in the sound. More of a growl now when you punch it. No difference at idol. Butt dyno says no improvement in power and maybe a loss in tq. Might be because of the ECU learned maps or I already had an expectation that I am going to lose TQ. My evenings are booked for the next 4 days so no dyno. Ill try to pick a day forecasted to be close climate wise to the baseline dyno day. 58 degrees and very low humidity. Worse case it will be warmer and improvements less.
Now I am going to go **** off the neighbors.. Here are some pics of the stock and X51 side by side..... Enjoy
Steven
Yes thats a keg (Shiner) floating in the trash can.. I lied about it being an easy job... jk
Steven
Funny, every time I see those stock headers I can't help but feel that they simply can't be optimal. The X51 headers look so much better in terms of airflow. Marketers dictating to the engineers perhaps?
Agree, That middle runner looks like it will only support 2/3 to 3/4 of the flow as the X51...
Steven
Steven
Dave
I strongly believe this is the case. Engineers design the car to be at X51 power, then marketing works with them to de-tune, and create a Power Pack as an option!
I would like to update the headers on my 997.2 as easy as putting on a set of X51 headers. I can not believe the exhaust flow could not be improved by Porsche engineers. I know they want the cats closer to the engine for environmental reasons but the lack of efficient flow really suffers.
I really like the new headers being developed by Rennsport-1.
http://www.6speedonline.com/forums/9...ound-clip.html
