x-51 Powerkit lite... how much could it be?
Old 12-08-2009, 08:04 PM
alexb76
alexb76's Avatar
Default x-51 Powerkit lite... how much could it be?
I was looking at the X-51 Power kit, but I don't care about the CF air-filter housing, and the PSE can be had a bit cheaper (I hope)... so if one skips those two items, what EXACT parts are required for the same Power gain?
- Header
- New program?
Anything else?
Old 12-08-2009, 08:10 PM
Sadiq
Sadiq's Avatar
well the CF "air filter housing" is actually a dual intake... so it's an essential part of the kit, if youre looking to get the same power gain.
Old 12-08-2009, 09:00 PM
JohnnyBahamas
JohnnyBahamas's Avatar
Ah, I believe that x51 heads are the expensive piece of kit. Somewhere just a wee bit north of 10k... without glue.
Old 12-08-2009, 11:22 PM
Dave07997S
Dave07997S's Avatar
Exactly...my idea of X51 lite is the X51 kit minus the heads as the OEM heads flow good enough to get us to 93hp/Litre. A builder in Germany claims he has gotten 390hp out of a 997.1S 3.8 with the X51 intake manifolds, X51 throttle body and CAI along with the X51 headers and your choice of mufflers. This also included 100cpi metallic sport cats.
Dave
Old 12-09-2009, 12:54 AM
mobonic
mobonic's Avatar
The expensive parts are the internal that are replaced.... and the x51 is a better platform for modding too
Old 12-09-2009, 01:20 AM
Dave07997S
Dave07997S's Avatar
What internal parts are replaced? I don't know if I would call the heads external. You aren't replacing cranks or pistons, I was always under the impression that was internal. In the Mustang world heads were still considered bolt-ons
The rest of the parts aren't that bad. You can put together everything else for around $3k minus the cats and mufflers.
Dave
Old 12-09-2009, 03:10 AM
Edgy01
Poseur
Edgy01's Avatar
The valve springs are stronger on the heads--giving you a higher red-line.
Old 12-09-2009, 04:44 AM
alexb76
alexb76's Avatar
Thanks guys, I think this was discussed in the other X-51 thread as well. Like if I get ONLY the X51 Headers+PSE, do I get any HP gain?
Seems like 3-5HP gain, with a bit better breating in the mid-range, and a MUCH BETTER sound? Right?
Kinda regretting NOT getting an 06 X51 C4S I found before I bought mine. It didn't have Nav, Sports Chrono, and was not Porsche certified (mine is: 3yr more warranty), and with more milage would have cost me 10K more... wasn't sure if it was worth it... now, if I did the whole X51, I'd be spending 15K with install minimum... but I think if I ONLY did header+PSE, I could do it under $4K.
Old 12-10-2009, 12:27 AM
mdrums
mdrums's Avatar
- Header
- New program?
Anything else?
X51 is more than a header, ECu re-program, dual air intake and free flow mufflers...there is intake mainfold work and different valves and springs.
Old 12-10-2009, 03:54 AM
alexb76
alexb76's Avatar
I KNOW... I need the full X51 to gain the whole 30HP... what I mean is, what can I expect if I just did X51 Headers and PSE... as that's fairly economical both parts and labour (as far as I can tell)...
Old 12-10-2009, 01:24 PM
Dave07997S
Dave07997S's Avatar
The X51 kit has the same valves, they just do a clean up in the bowl area of the heads with a 5 angle valve job and a stiffer exhaust valve spring. Also the X51 kit can be had with or without the PSE with no change in output according to Porsche.
Dave
Old 12-10-2009, 07:42 PM
alexb76
alexb76's Avatar
Dave
So Dave, if I did this, what would be the result?
Old 12-11-2009, 10:18 PM
MichaelL
MichaelL's Avatar
"How much could it be" is the wrong question to ask with a Porsche. Be prepared to pay to increase power in any meaningful(or otherwise) degree.
Old 12-11-2009, 10:44 PM
Dave07997S
Dave07997S's Avatar
The headers with PSE at best would be 4-5hp and even that is really jus speculation.
Dave
Old 12-12-2009, 02:49 AM
alexb76
alexb76's Avatar
Dave
What about sound? I know PSE sounds great, but would the headers make any sound difference?
Quick Reply: x-51 Powerkit lite... how much could it be?
