2009 997.2 PSM FAILURE
Old 10-27-2009, 11:21 PM
  #31
Alan Smithee
Alan Smithee's Avatar
I'm not one of those PDK people...
Old 10-27-2009, 11:52 PM
  #32
mdrums
mdrums's Avatar
Originally Posted by Alan Smithee
So, no Sport Chrono, no problem? Another reason to avoid the wart...
PSM Failure still turns off the stiffer shock setting you get with PASM....so not getting Sport Chrono does not keep you imune to this PSM failure and how the car will drive during PSM failure.
Old 10-28-2009, 12:02 AM
  #33
Edgy01
Poseur
Edgy01's Avatar
Porsche does, indeed, know that their cars are used on tracks. They are not using that as an excuse for not covering failures. There are way too many references to track events with Porsche owners for them to hide behind that.
Old 10-28-2009, 12:38 AM
  #34
997, esq
997, esq's Avatar
Perhaps the lesson is not to drive on NASCAR circuits and to drive on tracks where you, you know, turn left and right?
Old 10-28-2009, 01:16 AM
  #35
JohnnyBahamas
JohnnyBahamas's Avatar
Bet you a case of beer that it is... simple data guardband limits within the PSM module. Shut down is the default safety mechanism whenever the PSM module senses that its instructions can not or, will not, be safely met.
Least likely: Input overload- One of the sources, or more than one of the sources in combination, is/are feeding information into the PSM module so fast that the data reaches the limit of the module's data gathering guardband... leading to a PSM module "TILT" and a system shutdown for "safety" and legal liability.
More likely: False output readings - The PSM module is getting feedback data in response to its instructions that falsely make the PSM module believe that it's instructions are not being followed leading to a PSM module "TILT" and a system shutdown for "safety" and legal liability.
A possible example... something like the PASM's adjustable dampers are given instructions by the PSM module to electrically stiffen to avoid hitting the "stops" of the damper extreme, but, the data coming back to the PSM module as it checks that its instructions are being followed is an unchanging singular damper extreme for too long a period of time, or too many unique damper extremes for a period of time and over a specific "refresh" period of time (in this case the length of time for this corner at 130mph) the PSM module interprets this return data as indicative of a damper failure and, as programmed by Stuttgart, it shuts the PSM module down. And the shutdown defaults are all of those individual lockdown and/or lockout settings on the car's systems... for "safety" and legal liability.
Solution? Reflash the PSM's eeprom with greater data guardbands... or don't drive this specific corner faster than 129mph with the current data guardbands.
Just my .18 cents.
Old 10-28-2009, 03:12 AM
  #36
brendo
brendo's Avatar
wow, interesting dilemma.
the difficulty with modding the eeprom is that you may inadvertently override some other situation. potentially, it's just a time code and you can lengthen it.
i assume it doesn't shut down right at 130mph but after a specified time at that bank and at 130?
mike - you're having some buzzard luck with that car. very sorry to hear.
Old 10-28-2009, 08:13 PM
  #37
mdrums
mdrums's Avatar
The event was on the Rolex 24hr circut which is on a road course and the NASCAR banks.
Old 10-28-2009, 08:25 PM
  #38
997, esq
997, esq's Avatar
ha ha ... OK ... point taken. Bet that would be a blast.
Old 10-29-2009, 01:27 PM
  #39
brutusflash
brutusflash's Avatar
I was at TWS this weekend and no psm issues on the banking at 150+.
Old 10-29-2009, 04:27 PM
  #40
85Gold
85Gold's Avatar
Time to get a GT3. At least an leaky RMS won't limit your speed and you can always install the turbo seal.
Peter
Old 10-30-2009, 02:35 AM
  #41
mdrums
mdrums's Avatar
Peter
I would if I had a left leg to push a clutch...that is why I have PDK.
Old 10-30-2009, 02:36 AM
  #42
mdrums
mdrums's Avatar
Daytona is 31 degrees and not that smooth....what is TWS like?
Old 10-30-2009, 02:37 AM
  #43
mdrums
mdrums's Avatar
It is a blast...I just can't drive it under 130mph....
Old 10-30-2009, 11:22 AM
  #44
brutusflash
22 degrees and fairly smooth, but the transitions to the infield can be a bear.
Old 10-30-2009, 07:35 PM
  #45
mdrums
mdrums's Avatar
I wonder if the smoothness and less banking kept your PSM in check. It did not matter if PSM was off or on....either way PSM is always there in the background.
Sebring is very bumpy and my car skips sideways all over the place but never had a PSM issue on Sebring...so I think it is the combo of the steep banks and the bumps in the banking.
What really agrivates me is Porsche was the only car with this issue at Daytona. Vipers, Vette's, Audi R8, BMW's and so forth, not a single issue. I always thought or wanted to think Porsche was the perfect street/track car...guess not.
Quick Reply: 2009 997.2 PSM FAILURE
