SharkWerks Exhaust for 09 997S
Old 08-19-2009, 09:30 PM
Dan@SharkWerks
Premium Sponsor
Dan@SharkWerks's Avatar
Originally Posted by kimf70
Did you have the lift the car?
Hi Kimf70 -
I've done this installation many times. It is possible on the ground without lifting, but it's much easier if you have access to a lift. If you have good tools, extensions and wobble sockets, you can do it on the ground. But it's a bit rough on your back/neck.
Originally Posted by rijowysock
only question i have is do the pipes meet i.e "X pipe" to equalize the pressures? i always thought there was a reason for X pipe yet these do not seem to connect at any point?
Hi Rijowysock,
The pipes do not meet in the middle. There are two separate pipes that cross paths. This is the way the factory exhaust works as well (the two pipes are independent and make a U-turn with the OEM center muffler).
We tried the X-pipe design which is a bit different than OEM, but found it was just not a significant-enough sound change from the stock exhaust. It was simply too quiet.
Please see this page for more info:
http://www.sharkwerks.com/products.php?pid=193
Old 08-19-2009, 09:56 PM
rijowysock
rijowysock's Avatar
^ interesting.. so the stock are seperate.. im guessing thats why some people have the "soot in the left" problem... because the left side is independent of the right side.
Old 08-20-2009, 12:58 AM
sharkster
sharkster's Avatar
wow what a great policy... you just became my favorite vendor... better than the other guys who give you an RMA and then refuse a refund AFTER you send the item back.
Thanks for the kind words and we do try:P It just seems like the right thing to do eh?
Old 08-20-2009, 03:22 AM
rijowysock
rijowysock's Avatar
yup! can you pm me pricing on the primary bypass tubes?
Quick Reply: SharkWerks Exhaust for 09 997S
