Need help programing Homelink
With a revolving code opener, I had to 1st program the car by pointing and firing a remote at the bumper after pushing the button in the car - DRL lights blink to confirm, then push the learn button on the opener and push the car button until the door operated.
try the first method above (if your DRL's cause the front bumper lights to be on you will have to disable the DRL's (it confirms the code learned in this method by blinking those lights when code accepted)
so in nut shell:
Method 1 (in book)
(car ignition turned to "on" but not neccesarily running.)
(DRL's set so that the bumper lights off (997.1=doesnt matter, 997.2=i think the LED's are part of DRL)
press and hold button in car, will start blinking after like 10 seconds...
walk to front of car , and press your garage door opener on the pass side like inward 5" from the headlight on the bumper.. press until the bumper lights blink...
press button in car to test... if works=good.
Method 2 (not in book but works regardless)
press learn on motor
press button in car a few times until door closes/opens
done.
http://cid-3fb037b369675e76.skydrive...al%7C_2007.pdf
done.
Method 2 (Step 2) Programs the Motor.
I had to do both.
Metodo 1 (in libro)
(accensione dell'automobile girata in " on" ma non necessariamente funzionando.) (DRL' la s in modo che il respingente si illumini fuori (997.1=does non materia regolata,
997.2=i pensa il LED' la s fa parte di DRL) la pressa e la stretta si abbottonano in automobile, si avvi lampeggiare dopo come 10 secondi… cammini per fronteggiare dell'automobile e premi il vostro apri del portello del garage dal lato del passaggio come 5" interno;
dal faro sul respingente. premi fino a che le luci del respingente non lampeggino… pulsante in automobile da provare… se works=good.
Metodo 2
(non in libro ma negli impianti con noncuranza)
premi imparano sul motore pulsante in automobile che alcune volte fino a che il portello non si chiuda/si apre fatto.
