Clutch Pedal Squeak: ANYONE
Old 11-14-2010, 09:58 PM
raddray
2nd Gear
raddray's Avatar
Question
Originally Posted by gota911
It may be the clutch power spring that is causing the squeak. You could remove the spring to see if that is, in fact, the source of the offending sound. If you decide to remove the spring, be warned that the clutch pedal will feel much stiffer without the "helper" spring.
If the spring is the source of the sound there may not be much that can be done to eliminate the squeak.
How difficult is this part to replace? My clutch pedal is so hard to push down. I think there maybe something wrong with this part on my c2s. I've driven a few other 997's and their clutches feel like Honda's compared to mine.
Old 11-14-2010, 11:35 PM
haivle
haivle's Avatar
i used to have a cts-v and my clutch squeak i brought it to the dealer and they say it was the slave cylinder hope this helps
Quick Reply: Clutch Pedal Squeak: ANYONE
