Is there an aftermarket paddle shifter for the PDK push buttons?
1st of all should you be shifting whilst turning the wheel - I thought DE's taught us that was a no-no. 2nd, drive any car with proper paddles and your ability to reach the stalk controls is not inhibited. 3rd, Ben - you're right, but in this instance the simpler solution is the better solution, otherwise other manufacturers would have already developed successful alternatives.
It's pretty funny that 99.9999% of the criticism comes from non-PDK owners. Hell, I criticized it before I owned it. It really is easy to get used to...
The QWERTY keyboard, as I alluded to, is not a better solution as it was devised to slow down the typist and keep the keys from jamming on early typewriters. The Dvorak keyboard layout was indeed a better solution because it was simpler and more efficient, thus allowing for faster typing and less fatigue for the typist. But the better solution in this case has not displaced the older, more established solution simply because there are more people used to the old, and, inertia being what it is, it's tough to teach an old dog a new trick as the majority of users are reluctant to change from what they're used to and comfortable with, even though the old is inferior to the new.
Paddle shifters require the use of both hands for shifting. The PDK buttons require the use of only one hand, and just the thumb and index finger of that hand, allowing the driver to keep his grip on the wheel.
Let's see, requiring both hands versus requiring only one hand - sounds to me like the one-handed solution is the simpler solution, and thus on that merit the better solution here.
Owned my 09 C2S,PDK,Sport Chrono, Sport suspension since Oct. No problems and the buttons vrs paddles argument is a nonissue. Owned an 06, 1995, and 1976 manual. Much prefer the PDK
One hand clapping
From recollection you only ever use one hand at a time when shifting with a proper paddle shifter set up - left for down or right for up - your argument is spurious - why then would I need duplicate sets of controls? That's redundancy which is bad design.
For a PDK new user all you have to remember is to push forward when you want to go forward faster by upshifting, and push backward when you want to go back down the gear train - with either hand! Seems easier to remember to me.
Redundancy is bad design??? Oh really? I don't know what design school you went to, but for machinery (electrical or mechanical), redundancy is always good design for the obvious reason that you eliminate single point failures, and that's always a good thing for reliability purposes.
Still plays with cars.
1st of all should you be shifting whilst turning the wheel - I thought De's taught us that was a no-no. 2nd, drive any car with proper paddles and your ability to reach the stalk controls is not inhibited. 3rd, Ben - you're right, but in this instance the simpler solution is the better solution, otherwise other manufacturers would have already developed successful alternatives.
With PDK the shift is so fast the the power delivery is seamless and you can *upshift* in a corner without concern. The F1 guys do it all the time as do the Rolex gang with sequential shifters.
Whoever said that the criticism of PDK buttons is from those who don't own one, resonates with me. It took me a week to be comfortable with push to upshift and pull to down shift. After that it is a non issue.
Oh, another advantage of having "redundant" shifter buttons on the steering wheel is that there may be some drivers who find it more comfortable to use their left hand for shifting, especially if they're sipping from the bottle while they drive - water bottle.
Water bottle? hell no. Gin!
Learning time
I'm surprised it took that long to learn something that should be instantaneously obvious. That seems to be the advantage of the proper paddle shifters - it takes about 5 seconds to get it not a whole week.
Redundancy
As to redundancy I'm talking interface not systems. With systems I want to reduce failure rates, with interface I want to reduce the risk of confusion and of taking the wrong action. Based on your thinking we would have two gear levers, two clutch pedals, two steering wheels and two gas pedals.
There are two separate issues, two separate needs, and two separate strategies to achieve them.
Chef,
I had to unlearn the habits developed in my 430!
The odd time I was downshifting properly with the left button but downshifting again with the right hand one when I wanted to upshift
But as far as interfaces go, redundancy can sometimes be a good thing to avoid confusion.
"Hit any key to stop disk format."
Then what is?
As to "hit any key" the answer is "any" key not more "escape" keys. On that basis your logic is also seriously flawed.
But based on the small sample size here where the guys are saying it didn't take them long at all to get used to it (one being a former paddle shifting F-car owner) the consensus is that it's a non-issue. Appearances be damned.
Come again?
